07-27-2007, 06:04 PM | #1 |
Keep Your Nose Clean
Will this work? (or miserably fail)
I welded some 4 nuts (I said nuts ) to the inside frame rail and bolted the blazer conversion kit tank to the frame? Has this worked for anyone or is it destined to fail miserably ? Please resond without words like idiot and stupid (unless you feel its absolutely necessary).
07-27-2007, 06:11 PM | #2 |
Re: Will this work? (or miserably fail)
I'm sure it will hold but it would be my suggestion to run the straps with those bolts to help distribute the weight of the tank and fuel across a wider area.Seems to be alot of weight hanging on that seam otherwise. Just my .02 though.
Frank
70 chevy lwb c10 454/th400 and a 9" rearend suicide doors, marker light fuel fill, 4" cowl , mini tub |
07-27-2007, 06:21 PM | #3 |
I dont see why it would not work, I would run straps too, the only thing i would think would be a problem is the bold tring to losing up since there is no lock washer
70 C10 SWB stepside forsale 00 Silverado Z71 Sold 95 Eagle Talon TSI turbo (Hellz ya its fast) 70 Chevelle 69 firebird 10 Silverado 4x4 |
07-27-2007, 06:25 PM | #4 |
07-27-2007, 06:32 PM | #5 |
Gasoline = 6 lbs / gal........not sure what the capacity is but probably not any more than 150lbs when full.
Looks fine to me......I would just check it occasionally. ..and if it does miserably fail, it will be far worse for the guy behind you than yourself!!!
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - My Build Thread Last edited by SactoJim; 07-27-2007 at 06:33 PM. |
07-27-2007, 06:38 PM | #6 |
Maybe...or maybe not? The trucks going to be lowered 6" at the rear. Hey, at least I won't lose my gas. 20 gallons of unleaded is about as expensive as the tank itself here in California.
07-27-2007, 06:22 PM | #7 |
You think It would be enough to run 2 straps parallell to the frame?
07-27-2007, 06:24 PM | #8 |
YA 2 straps should be fine thats how they do them on the cars
07-27-2007, 07:28 PM | #9 |
Still Just Havin Some Fun!
Where did you get the tank? I like the set-up. Mine was converted by the PO and the tank almost drags the ground. Needs a fix........
a green one with some stuff done to it.... |
07-27-2007, 07:53 PM | #10 | |
07-27-2007, 07:55 PM | #11 | |
07-27-2007, 08:04 PM | #12 |
Project Junkie! Fishing Poor!!
Well I would use the straps. The lip on that tank is not designed to take the weight plus the vibration of the tank full of gas. Also add to the fact that your frame is flexible and is constantly moving (this is why your frame is rivetted together, not welded) I think it won't be long untill you either break the weld in the flange, or crack it bad enough for it to start leaking. The engineers designed the tanks to be strapped in for a reason. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
07-27-2007, 08:17 PM | #13 | |
07-27-2007, 08:29 PM | #14 |
Wes, from classic heartbeat pickup parts, can more than likely get you a good deal on one too. You can find a link on post #15 of this thread.
07-27-2007, 08:16 PM | #15 |
its all about the +6 inches
I agree with Wes... esp when you consider that today... 40 years later, they still do it the same way.
Your idea looks very clean and would be awsome on a show circuit truck, but if you ever put fuel in it, I would really consider straps, esp in a state where personal lawyers are more common than personal responsibility. |
07-27-2007, 08:34 PM | #16 | |
07-27-2007, 08:56 PM | #17 |
The aluminum tanks are a little different than the steel tanks. Most aluminum tanks are designed to bolt directly to the frame. The reason is they do not use the flange as a seam too. Most have thick angle stock welded to them that can take a little more flex. I would not want to be in an accedent with one though, because all it would take is one frame rail to be pushed back a 1/4" or so to tear the tank out. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys Last edited by Classic Heartbeat; 07-27-2007 at 08:56 PM. |
07-27-2007, 08:37 PM | #18 |
in your state, I would too. if it doesn't have a DOT certification number for that model number vehicle, the laywers would have fun batting you around like a cat with a ball of yarn.
Same thing if someone gets hurt from the fuel after rear ending you. |
07-29-2007, 02:12 PM | #19 |
Chief Honcho In Charge
Exactly why I have my truck in an LLC. Among other things.
Privay and Asset Protection. The only remedy is the insurance pay out. Exactly where I want them to go. I can't stand being batted around like a toy. Tim
1992 1500 4x4 Shortbed 1984 Ford F250 Supercab Longbed 6.9L Diesel 1972 K10 Cheyenne Super Fleetside Short Bed - 350 - A/C 1971 VW SuperBeetle 1960 Wife 1984 Son 1986 Son 1989 Son Previous Trucks 1967 C10 SWB (1980-1981) 1971 C10 LWB (1998-2004) |
07-29-2007, 03:16 PM | #20 |
Looks good at 20-ft .....
71Tahoe: Is it just the camera angle, or isn't that tank low enough that a flat (especially a blowout) will put the tank bottom onto the pavement ???
I'm planning a rear tank, too, but it looks to me like it really HAS to be mounted higher up to the bottom of the tank than an imaginary string-line drawn bewteen the two rear wheel rims, or a flat on one (or Heaven forbid, both) of the rear tires would cause you to drag the bottom out of the tank, while you're also making lotsa sparks. A bad combination............... |
07-27-2007, 10:21 PM | #21 |
I'm always up for a good deal! Wes? are you the good deal maker?
07-28-2007, 08:16 AM | #22 |
I'll be installing my tank kit soon, so this thread is timely.
I think it'll work fine. I also think you've touched on most of the major issues, strength, safety, appearance. The thread does cause me to think though. Car makers have to build their tank supports to withstand all kinds of crashes. Though a little unsightly, straps and J-bolts will support the belly of the tank well, but offer the added benefit of releasing the energy of a rear end collision more slowly (lower G forces) without tank rupture. A "hard" mount like yours, in the very unlikely event an 18-wheeler rear-ends you, is more likely to rip the tank open and spew fuel. On the other hand though, under a lowered pickup bed I think a mount like yours is less hazardous than the same setup would be under a Blazer or a car (and a whole lot safer IMO than the truck's internal tank). Finally, because this thing isn't going to be a daily driver plus you'll be driving it more cautiously, statistically you're less likely to ever encounter such a situation. Overall I like your approach and just may use it myself. Thanks.
69 C-10 SWB Fleetside 454/TH400 (For Sale) http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12 70 El Camino 454 TH700 29 Model A 4-DR Sedan Deluxe |
07-28-2007, 09:30 AM | #23 |
Accedents can happen at any time. Driving the truck less and thinking that well I am on the road less is only playing russian rulet with your life and any other that may be involved in an accedent. Let's remember, accedents involve more than one vehicle, unless you run it off the road or something like that. Gas tanks are strapped for a reason. Even semi trucks strap their tanks to the truck. I believe that the bolted aluminum tanks can take a better hit, however it will rupture faster than if it was strapped in. Longhorn Man hit on another point also. Law... I am sure that there must be something in the law books covering this issue... Why else would manufacturers go through the added expence of strapping them in. WES
07-29-2007, 01:34 PM | #24 |
I'm listening carefully to all that is bieng said here. I think i'm going with a "modified" strap set up. I'll post the pics as soon as its done.
07-29-2007, 02:03 PM | #25 |
This is what I wound up doing on my son's truck.
Got rid of tabs on the driver's side of the tank and rounded one end of the square hole with a dremel Drilled and tapped an aluminum plate 7/16-14. It doesn't show it but the final assembly got nuts on the back to lock the bolts 1 1/2" spacers Had to drill 1 extra hole in the side of the frame for the forward j-bolt. I used an old inner tube from a 26" 10speed bike between the frame/tank/straps I think next time I'll get rid of the tabs from both sides and insert a long bolt down through the frame on the passenger side, tighten the straps and lock with a bolt on top and bottom of the strap. The j-bolts were a real pain. Last edited by 71tahoe; 07-29-2007 at 02:09 PM. |
