installing cab corner moulding?
My cab corner moulding (6) has disappeard! ![]() ![]() Anyway, going to get another one, but not from LMC! They want 119$ for just one! I have a buddy that has a few part trucks and see if he has any laying around. I was going to get another mounting bracket (8) from LMC cause its only $5 and I think mine is broke (thus it flyin off!). Finally, here's the question. How do you get the corner piece on? I looked at the bracket and don't understand how it goes on. I know it slides into the mouling on the back of the cab, but how does the mounting bracket work? Thanks.
Robert Current: 1986 SWB Silverado 4.3 / TH400 Past: 1985 SWB Silverado 305 / TH350 - sold 1995 1987 1/2 ton Silverado - FI 350 / 700R4 sold 2007 |
Re: intalling cab corner moulding?
Look inside the cab on that corner. Chances are there's a spot that a couple of nuts attach from the clip there.
The Crazy Machanic
Re: installing cab corner moulding?
ill have to take mine apart but like prong said most likly it slide onto the back one then get screwed down on the side. It should sslide into the corner molding have a thread part sticking off and have a nut that screw down onto it. Just like the rear corner molding does on the bed.
Actually if you look at 8 it shws a small rod with a nut at the end of it.
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day) ![]() * 1970 chevelle 2dr sedan Latest update June 24 2007. ![]() *1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad) ![]() newest additions 1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in and a 79 c60 trash truck um no idea i have one ![]() Last edited by Srubydo1986; 07-29-2007 at 06:52 PM. |
Slots go on anything!
there is a nut inside the cab corner. take that off, and the corner molding will pull loose. I think there is two different designs for that cab trim, though.
On the one I pulled off recently the mounting bracket had springs(?) on each side. To remove the trim you pushed up on it until the top was clear of the top side of the bracket then just pulled it off the bottom.
Might be different for differnet years though?
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) |
