Old 07-29-2007, 09:05 PM   #1
timcos
Chief Honcho In Charge
timcos's Avatar
Steering box options
OK...here is the reason I am asking the question.
http://www.67-72chevytrucks.com/vboa...d.php?t=249951
I think the steering gear box is screwed up.
So if I have to replace it...what are the best options?
I am also going to replace the pitman arm...I think it is a bit worn...along with the drag links and the adjusting sleeve.
So while I am in there...might as well go for broke.
1992 1500 4x4 Shortbed
1984 Ford F250 Supercab Longbed 6.9L Diesel
1972 K10 Cheyenne Super Fleetside Short Bed - 350 - A/C
1971 VW SuperBeetle
1960 Wife
1984 Son
1986 Son
1989 Son
Previous Trucks
1967 C10 SWB (1980-1981)
1971 C10 LWB (1998-2004)
timcos is offline   Reply With Quote
Old 07-30-2007, 06:40 PM   #2
timcos
timcos's Avatar
Re: Steering box options
ttt
1971 VW SuperBeetle
1960 Wife
1984 Son
1986 Son
1989 Son
Previous Trucks
Old 07-31-2007, 11:47 AM   #3
timcos
timcos's Avatar
ttt
1971 VW SuperBeetle
1960 Wife
1984 Son
1986 Son
1989 Son
Previous Trucks
Old 07-31-2007, 02:07 PM   #4
Truckstr
Truckstr's Avatar
http://store.summitracing.com/partde...5&autoview=sku
This is the one that I went with. I'd like to say I love it, but I haven't gotten my truck back together to see.
Jeff
'67 short Fleet; my ongoing project.
'66 long Fleet; my original "baby."
Live life or bust trying.
Truckstr is offline   Reply With Quote
Old 07-31-2007, 05:05 PM   #5
timcos
timcos's Avatar
What about that one makes it 100 bucks better than stock?
1971 VW SuperBeetle
1960 Wife
1984 Son
1986 Son
1989 Son
Previous Trucks
Old 07-31-2007, 05:10 PM   #6
Musclerodz
Variable steering ratio as all modern cars have today would be the only benefit.
Mike
Mike Redpath
Musclerodz is offline   Reply With Quote
Old 07-31-2007, 03:52 PM   #7
itsmike2k
What does it mean by "Fits model with after market crossover steering only." on the application chart of that box?
Mike
1972 LT1/4l60e Short Bed
ART Front and Rear Strong Arms
http://www.67-72chevytrucks.com/vboa...50#post2151750
itsmike2k is offline   Reply With Quote
Old 07-31-2007, 05:07 PM   #8
Musclerodz
Means it fits 2wd trucks and 4wd with cross over steering. We sell AGR boxes, and though they are not the best out there, they are the best for the price. There are better boxes out there, but be prepared to pay $450 and up. I have sold quite few boxes with no problems so far. If you decide on the AGR box, we should be able to match Summits price.
Mike
Mike Redpath
Old 07-31-2007, 08:17 PM   #9
timcos
timcos's Avatar
Do I have crossover steering on my K10? It is stock as far as I can tell.
What is the best one out there...and why would not go to the 450 point...what more is one getting?
What is a variable steering ratio?
1971 VW SuperBeetle
1960 Wife
1984 Son
1986 Son
1989 Son
Previous Trucks
Old 07-31-2007, 08:36 PM   #10
timcos
timcos's Avatar
OK...here is a good explanation...and that makes a ton of sense to me.
Some cars have variable-ratio steering, which uses a rack-and-pinion gearset that has a different tooth pitch (number of teeth per inch) in the center than it has on the outside. This makes the car respond quickly when starting a turn (the rack is near the center), and also reduces effort near the wheel's turning limits.
So most likely our steering box has a rack and pinion but no variable teeth?
Or do we have Recirculating-ball Steering gear boxes?
I think I would like to install a Drive By Wire System
1971 VW SuperBeetle
1960 Wife
1984 Son
1986 Son
1989 Son
Previous Trucks
Old 08-01-2007, 08:43 AM   #11
Truckstr
Truckstr's Avatar
Sorry I didn't respond earlier. Musclerodz stepped up and gave good input. I felt I didn't need to comment.
No, our trucks don't come stock with rack and pinion steering. It is the recirculating ball type, but not variable ratio. There are rack and pinion steering systems adaptable to our trucks (there are guys on this site that have it), but it isn't stock.
As far as variable ratio, recirculating ball type power steering systems go, the advantage is a higher rate "turn in" of the wheels at low speeds (as would be ana advantage in a parking lot) versus the need to have less "turn in" - which could equate to what I'll call "twitchiness" - at higher speeds. The stock units are the same steering ratio regardless of vehicle speed. I forget the stock spec, but it's pretty high. Something like 22:1 (don't jhold me to that).
Does that help?
Also, like Musclerodz says, the AGR unit may not be the best unit out there, but it has a very good reputation for the money. Better units, that do essentially the exact same job in the exact same way, are more expensive. It's up to you to decide. Just keep in mind that even re-manufactured stock units aren't much lower in price than the AGR unit.
Jeff
Old 08-01-2007, 08:45 AM   #12
Truckstr
Truckstr's Avatar
Drive by wire? That would be a first in one of our trucks, I would imagine. I can't imagine why you'd want to go to that extreme. THAT would be expensive. I'm not even sure where to start on something like that.
A bit "over the top", if you ask me.
Jeff
Old 08-01-2007, 10:47 AM   #13
timcos
timcos's Avatar
Yeah that was a joke...would be thousands if you sould even get your hands on it...it would increase the steering wheel placement options.
1971 VW SuperBeetle
1960 Wife
1984 Son
1986 Son
1989 Son
Previous Trucks
Old 08-01-2007, 10:15 AM   #14
itsmike2k
So what is the cross over stering?
Mike
Old 08-01-2007, 10:55 AM   #15
msgross
msgross's Avatar
this is what extreme off road chevy guy do to their rigs. They put a 2WD (side to side steer) in place of the 4wd (fore and aft steer) geerbox. Then connect that to the pass side flattop knuckle (aka crossover) which has machined to attach a steering arm. Then the stock tie-rod steers the driver side. Kind of like a jeep or F*rd setup. This allows them to lift the truck 8+ inches and still have a good angle on the drag link. Stock setups creat a lot of bumpsteer when them truck is lifted since the drag link on the driver side is so short, it creates an extreme angle and doesn't turn very well.
google crossover and you will see a lot of information on it, plan on big $$$ for this mod. Not needed for the average 4WD though.....
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 08-01-2007, 11:38 AM   #16
itsmike2k
So basicly the box Timcos is talking about does not fit our trucks with stock steering.
Mike
Old 08-01-2007, 12:02 PM   #17
Thealien
Thealien's Avatar
I am very happy with my red head steering gear that I installed a couple of weeks ago. It was around $330 including shipping and a $60.00 core charge. Although with shipping to return my core return will be closer to $30.00. So actually my box cost me $300
http://www.redheadsteeringgears.com/
Old 08-12-2007, 07:22 PM   #18
timcos
timcos's Avatar
Sort of weird but my steering box is acting OK...been tooling around town taking it easy.
Can I just get a new pitman are (old one worn out I am sure) and just realign where it attaches? That way I will have good side to side steering.
Would rather spend the bucks on pitmanarm , drag links, drag link sleeve, tie rod ends...you know all the wearable stuff to tighten up my steering.
1971 VW SuperBeetle
1960 Wife
1984 Son
1986 Son
1989 Son
Previous Trucks
Old 08-14-2007, 03:50 AM   #19
Ivan D.
glamoros piece o' lowlife
Ivan D.'s Avatar
Sure you can do that, it's the suggested steering rebuild way anyways - stering boxes themselves rarely fail, steering linkages however do wear out much easier, so replace the drag link and the tie rods, pitman arm only if it has the flex-joint attached to it - if both flex joints are part of drag link (forgot how the exact K-setup looks like, and I got a 2wd) don't bother with the pitman arm.
The more I drink, the more I drink, the more I drink...
diesel, reg cab, long bed, 4 across the rear, single stack, wooden stakes, and lotsa lights - the Hay Express
Ivan D. is offline   Reply With Quote
Old 08-13-2007, 11:48 PM   #20
timcos
timcos's Avatar
ttt
1971 VW SuperBeetle
1960 Wife
1984 Son
1986 Son
1989 Son
Previous Trucks
