08-01-2007, 12:31 PM | #1 |
New ORD flip rear shackles installed
I finished them this morning I put them on a 83 3/4 ton longbed 4wd after a test drive i love em. The whole truck rides smoother and i dont have all that squeakin and popping i did with rear blocks.It sits a little higher in the rear thay make a front shackle that will cure that. I fell it was money well spent and they look cool to
08-01-2007, 01:52 PM | #2 |
Re: New ORD flip rear shackles installed
Have some pics?
08-01-2007, 05:06 PM | #3 |
a few i already put my truck up. here goes
08-03-2007, 02:50 AM | #4 |
Those are nice, so how much did they cost?
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
08-01-2007, 06:23 PM | #5 |
Looks good, I would like to put some on my 61 4x4 but nobody makes them for 60-66 4x4's. I wonder if the 67-72's would work on my truck? Oh well, nice job!
08-01-2007, 06:59 PM | #6 |
thanks, i found the instructins after i was done they said the shackle should be turned around,not sure why it does the same thing i called but stephen was busy hes very helpful. Wonder if you had the measurements if you could make them work on your truck? i am releived to get the blocks out,i also gained some exta wheel travel with a smoother ride.
08-02-2007, 10:33 AM | #7 |
Can you compare your rear axles front spring hanger to one from a 67-72? Worst case scenario, you might have to use 67-72 rear axle front spring hanger.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
08-02-2007, 04:28 PM | #8 |
I thought about changing all the spring hangers to 73-87, but I guess the 67-72 would be the closet. The only thing is to find them, the salvage yards around here crush all the old stuff to quick!! I don't have any one around here that I know of that has a 67-72 4x4 to campare the front hangers to. I'll guess I'll have to search a little harder!! Jeremy.
08-02-2007, 07:37 PM | #9 |
i think the spring width from spring to spring may be an issue also
08-02-2007, 08:38 PM | #10 |
08-04-2007, 01:49 AM | #11 |
Ooooh I want some! |
08-04-2007, 07:28 PM | #12 |
the shackles are 189, the ubolts are 20,and shipping all was close to 250.
the results you get.....priceless |
08-05-2007, 12:30 AM | #13 |
72 chevy
Them do look nice i always do the cheap way.
then weld braces in but yours look so much better and heavier built Ed |
08-07-2007, 12:38 PM | #14 |
Junior Member
ed, the "cheap way" doesnt look that bad at all, has it ever failed on you?
1979 K10 reg cab short bed 33x12.50s - GONE 1988 4x4 reg cab long bed 337k miles - GONE 1995 Z71 GU6 G80 F44 ext cab short bed 149k 305/70/16s - GONE 1995 NZZ GT4 2dr Tahoe 3" lift 14 bolt sf 155k 305/70/16s - GONE 1994 Z28 M6 1995 Z71 GT4 G80 ext cab short bed 215k GONE 1997 GT4 G80 Yukon 4 door leather, sunroof 168k miles GONE 2003 Avalanche Z71 GT4 G80 165k miles Last edited by bufmatmuslepants; 08-07-2007 at 12:39 PM. |
08-07-2007, 06:43 PM | #15 |
i was lookingg at my truck how about if i took and cut right side and flipped it for the left side and cut left and put on right and added a longer shackle wouldn.t this get me a cheap set of shackle flip?
08-10-2007, 04:38 AM | #16 | |
USMC
Semper Fi |
08-07-2007, 07:14 PM | #17 |
72 chevy
Thats the simplest and strongest way i have found the way i did mine but i think next time it will be one of them ORD shackle flips there cool.
Ed |
08-07-2007, 10:29 PM | #18 |
K5Camper
I'm not sure of the homebrew flip and this is coming from one cheap SOB. I'm sure cutting a hole out of a stock hangar takes good amount of strength out of it. The added gussets help but it sure looks iffy.
You want a cheap way to do a flip go find a 2wd truck and swipe the rear spring front hangars from a junker. Put them in the rear. It just requires a lot of rivet cutting..
Rob Z. 1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP 1991 K5 8.1L/NV4500/241/D44/14b FWC Camper |
08-09-2007, 09:41 AM | #19 |
Nobody rides free
Look good. Had a chance to try them out yet?
Just thought I'd link this again, to show another option. Some other links in that thread too. http://67-72chevytrucks.com/vboard/s...d.php?t=190177 Shackle flip was the best upgrade I've made, really helped the flex.
'71 C10 LWB 400SB/350TH '86 K2O LWB 350SB/400TH-6" tuff country lift, Shackle flip - plow truck '06 HHR - wifes wheels '01 Blazer - daily driver "It's better to burn out than it is to rust." -Neil Young |
08-24-2007, 07:31 AM | #20 |
i am going to attempt to use the front shackle mount in the rear leaf to do a homemade shackle flip . can i use any year mount?
08-25-2007, 01:06 PM | #21 |
USMC
As long as it is the same width I don't think i matters were it is from. also check the diameter of the bolts and bolt holes
Semper Fi |
