08-01-2007, 10:32 PM | #1 |
What methods are you using
to drill the holes correctly in the frame to mount slam RE7's in the original coil spot. What a freakin headache. I have one half way done, but it took me two freakin hours.
08-01-2007, 11:29 PM | #2 |
senior member
Re: What methods are you using
im assuming you mean in the rear because the front plates should have already been done. in the rear I went and bought a hole saw just big enough so i could get the fitting through, then just ised a good quality bit for the3 other 2 mounting holes. I think i had all 6 holes drilled in less than half hour
69 GMC bagged |
08-02-2007, 05:00 PM | #3 | |
08-02-2007, 04:29 PM | #4 |
Outlandish Trends - FL
I had the same problem drilling my holes for the bag port. The hole is a 1" size. I went through 2 Unibits. But I was drilling through the CPP bolt-in cnotch, the frame, and the stock backing plate. It was a total PITA.
-Bret 67 short-fleet sold! |
08-02-2007, 06:39 PM | #5 |
holesaw... or if you have the access/resources get your hands on a plasma cutter, you can rent them from equiment rental shops, you could have all 6 holes done in about 2 minutes..
67' in the "build" process.. soon to be bagged, big wheels ect, finally got it back home!! |
08-02-2007, 06:58 PM | #6 |
Carbide 'burring' bit & high quality drill bits. I used drill bits stepping up to 13/16" & then opened up the hole as needed w/the carbide burring bit. Took about 15mins ea. side.
Many suggest the hole saw method but I used one on a hole I was drilling on the top side of the shock crossmember. Standing above the work, soaking the hole w/cutting fluid, & being able to use most of my body for support, it still took 5~10mins of solid drilling (about 25mins stopping to limit heat soak on the bit) & this was only 1/8" thick single wall mild-steel. I can't imagine lying on your back, pushing up w/only your upper body for force, & trying to drill through almost 1" thick steel (frame + frame support + c-notch support + shock crossmember support). The carbide burring bit made quick work of it. I bought an 8pc kit for about $150 but now I have them for other jobs (I could have just bought one bit for the job).
08-02-2007, 07:16 PM | #7 |
Not all holesaws are created equally. Trust me on this one. But, there's more than one way to get er done.
08-02-2007, 09:05 PM | #8 |
This was my assumption as well. At the time though, Home Depot was my only source for the hole saw so that's what I had to go with. After going through the BS I went through w/the holes I did on the top side..... I knew I had to seek an alternative method.
08-02-2007, 10:36 PM | #9 |
senior member
definately going to have to agree on that I tried used ones then cheap ones then finally broke down and bought a good one and I was thru in no time
69 GMC bagged |
08-02-2007, 09:41 PM | #10 |
You could also you a torch to punch a hole, then clean it up w/a uni bit and grinder
