08-07-2007, 12:05 PM | #1 |
a/c control levers
I think I got a problem. I ordered new a/c control levers as one of mine is broken. I looked at it last night and am puzzled for what to do. The shaft that the levers rotate around is held in place by a steel plate. This plate is set on two pins which are "hammered" flat to hold it in place. It looks like I need to grind off the pins to remove the plate and then the levers. All is good to this point. The problem is I dont know how I will hold the plate in place after re-assembly. This was much easier on the 68 which has heat only. I know this is probably hard to understand but if anyone does understand and has a solution, let me know. I may try to post a pic later to help explain.
http://www.picturetrail.com/jwill41 67 1/2 ton GMC short step side 68 1/2 ton Chevy long fleet side 72 1/2 ton Chevy Suburban 99 1/2 ton Chevy Suburban founder (and only member) of the primer/clearcoat club |
08-07-2007, 12:25 PM | #2 |
Re: a/c control levers
This was the only way I figured you could to it...
http://67-72chevytrucks.com/vboard/s...d.php?t=245558
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
08-07-2007, 12:58 PM | #3 |
thanks. That is exactly what I was talking about. I had thought about using screws but thought there might be another way. thanks again, very helpful.
