Old 08-07-2007, 12:56 PM   #1
Ryan P
Bags in front of axle?
Trying to bag the rear without cutting out the bed. Was hoping to use the kp 4 link, SD Behind and Under Axle airbag kit mounted on the front and aim super c notch. How big is the axle tube on the 88/98 trucks?
And can i weld the notch and bag brackets on before putting the 4 link on and get it lined up right, or will i need to wait till the 4 link is on?
Ryan P is offline   Reply With Quote
Old 08-09-2007, 12:01 PM   #2
Kontrol Phreaks
Kontrol Phreaks's Avatar
Re: Bags in front of axle?
And can I weld the notch and bag brackets on before putting the 4 link on and get it lined up right, or will i need to wait till the 4 link is on?
It's best if you get the 4 link installed first that way you can locate the axle under the truck, set wheelbase, center the axle between the rails, and get the pinion angle set. Once that's been done now you can install the bag mounts.
Axle tube diameter on the 1/2 trucks with a 10 bolt rearend should be 3 inches.
- Clint -
Kontrol Phreaks is offline   Reply With Quote
Old 08-09-2007, 08:01 PM   #3
Ryan P
Re: Will this rear setup work?
Ok cool. Do you sell a super c notch? Or a notch that will fit under the bed? How much does shipping run on the 4 link, not sure if i can get it this week or next.
