08-09-2007, 08:36 AM | #1 |
How to keep gasket in place when replacing oil pan?
Hey Guys,
I'm looking for any tips/suggestions on how to keep the oil pan gasket in place when replacing with the engine still in place. I've got a feeling that whole gravity thing is going to make things difficult. John O>.
85' CUCV M1009!!! The newest addition! 6.2diesel, Th400, NP208, & only 36k miles! 70' C-10 LWB Fleetside - Looking good these days! 05' Dodge Neon 88' Winner Escape Sport 1750 - 4.3v6 94' Seadoo SP 84' Honda TRX200, bare nekkid. Just a frame & tires. Always looking for another project or any good deal! |
08-09-2007, 08:59 AM | #2 |
Re: How to keep gasket in place when replacing oil pan?
rtv
08-09-2007, 09:17 AM | #3 |
I prefer the one piece gaskets myself. I know they cost more but they are a whole lot less frustrating.
I don't know of a magic way to install a standard set. Just make sure you do not over tighten as this can cause the front and rear gaskets to move and create a bad seal. Torque to 10#. esll.
Tomorrow is for doing today's stuff. ************************************* This truck has just the right amount of energy for me! Author: Warren Lake .... (member) |
08-09-2007, 09:41 AM | #4 |
Active Member
This is the way I do it and have been doing it for the last few times I've taken the oil pan out...
I take the pan off and clean the gasket surface real good with a flat blade scraper that I picked up (and of course clean the engine side also). I make sure the pan surface is flat. Then I put a bead of gasket adhesive or sealant to the oil pan only.. Buy a good quality gasket and lay it on the pan and use the bolts to insure it's in place and let it set/dry until it doesn't move. Sometimes an hour or more depending on the time that I have. I've had good luck doing it this way and when I do remove the oil pan again, the gasket stays on the pan... Last edited by 68gmsee; 08-09-2007 at 10:13 AM. Reason: sequence... |
08-09-2007, 09:14 AM | #5 |
Buy a (1) piece gasket. Instead of rtv, they sell some brush on stuff at the parts store that is a gasket adhesive, really cheap and works well.
05 2500HD 6.0 excab 69 LWB-Gone but not forgotten! 68 Dodge Charger 383/727 69 Dodge Charger-440/4spd |
08-09-2007, 08:43 PM | #6 |
08-09-2007, 09:37 AM | #7 |
permatex aviation form-a-gasket// i too prefer to spend the extra for the 1piece gaskets
08-09-2007, 10:30 AM | #8 |
thin layer of rtv
08-09-2007, 10:58 AM | #9 |
One thing to do as well is tighten the front two and rear bolts hand tight first. I was told that by my mechanic buddy and it really helped the 4 pc. stay in one spot while bolting it down. He uses the yellow "monkey snot" stuff, it works real well too. You know you will have to raise the motor up with a engine hoist for the pan to clear the front main too.
05 2500HD 6.0 excab 69 LWB-Gone but not forgotten! 68 Dodge Charger 383/727 69 Dodge Charger-440/4spd Last edited by OLDIRON69; 08-09-2007 at 11:00 AM. |
08-09-2007, 11:17 AM | #10 |
1997 GMC Sierra Ext 1965 Mustang |
08-09-2007, 11:44 AM | #11 |
Member
The last Fel Pro 1 piece gasket I bought came with 4 plastic clips to hold the gasket in place. I did not use them though, I had the motor out.
08-09-2007, 12:59 PM | #12 |
I have used string or zip ties to hold gaskets in place while installing back on engine. Just run a few in the bolt holes evenly around the pan (not every hole), after getting pan back in place, attach to engine by placing a few bolts in the holes without string or zip ties. Tip - do not tighten string or zip ties leaving loose just enough to be able to cut out with what ever means available. Afterward finish installing remaining bolts, tighten to specific torque. Don't forget to fill with oil afterward. hahaha!!!
Good luck! Eric |
08-09-2007, 01:43 PM | #13 |
Dave's not here, man
I too have the FelPro one piece. It's a little spendy but well worth the money and easy to install.
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 |
08-09-2007, 02:06 PM | #14 |
Little bit of rtv, make sure u peen the holes with a ball peen hammer before re installing pan
1968 Short Fleet 350/700r4 http://67-72chevytrucks.com/vboard/s...d.php?t=249435 1997 Bagged XtdCab Vortec350/4L60e http://67-72chevytrucks.com/vboard/s...44#post2286144 1993 XtdCab Longbed 4x4 6.5Turbo/NV4500 "Daily Driver" 1985 Toyota XtdCab 4x4 22re/W-56/Dual T-cases, Doug Thorley Header, Homebrew front and rear spring packs, Tons of Mods to suspension and drivetrain, 35" boggers, coming soon ARB's and 5.29's, Possible 4.3/700r4 swap |
08-09-2007, 12:49 PM | #15 |
Spanked once
Valve covers and pans , I have been using thread for years to tie them on and just snip off the access when done.
08-09-2007, 02:04 PM | #16 |
use 3M weather strip adhesive on pan side of gasket, after glueing gasket on pan turn pan over and let set for about an hour. it will stay in place for the rest of your life....... they dont call it gorilla snot for nothing.
bob
I BELIEVE IN JOHN 3:16 |
08-09-2007, 02:08 PM | #17 |
Resident Absorber
I use this, Fel Pro part number OS34510T. it comes with these 4 snap things that screw into the block. put your gasket in place, then snap the pan in place. install some bolts, then remove the snap things. easy japaneesy.
The best offense is a better DEFENSE! |
08-09-2007, 05:02 PM | #18 |
buy yourself four "studs " to replace the bolts on the front and rear corners. perferably one inch , that way you can set the pan up with nuts and have room to make sure all is straight then ease it up evenly
"spiiiider pig, spiiiiider pig, does whatever spiiiider pig does. " |
08-09-2007, 06:22 PM | #19 |
spray the gasket with COPPER-COAT SPRAY before installing on pan, then put your first bolt in as you lift... I've got one arm and it works for me.
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White |
08-10-2007, 06:13 AM | #20 |
I use 3M weatherstrip adhesive.
08-10-2007, 08:52 AM | #21 |
I ended up using RTV. I forget how sticky that stuff is... especially when its 103 degrees out!
08-10-2007, 01:22 PM | #22 |
The one piece gasket with the enclosed plastic studs is the way to go if the engine is in the vehicle. I'm sure the other methods using RTV work well. The one piece gasket is supposed to be re-useable too.
Baby Blue's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=652776 Project 68's Build Thread: http://67-72chevytrucks.com/vboard/s...17#post8442117 www.stonecolumnclassics.com Email: Josh@stonecolumnclassics.com |
08-10-2007, 01:29 PM | #23 |
I think I'll go 1 piece next time. I already had a old style gasket set in the garage & couldn't bring myself to spend the $.
