08-10-2007, 09:48 PM | #1 |
Did I fry my dist???!!!
I have a new (Pro-Comp) distributor that I've only pulled with once. My problem is:
I did some welding to the frame a couple days ago.....Started it up and pulled it into the Garage. It started and idled fine before I shut it down. Today I went in to move it out, and now I have no spark!! I switched complete caps and it didn't help. Since I forgot to remove my positive batt cable, I think i fried something. I have almost 14 volts to the dist, and It turns over too easy. What would I check inside the dist under the rotor???? I'm hoping it's something silly that I'm overlooking....especially since it started and drove fine AFTER I welded. any hints would be appreciated. A..........
69' 3/4 4X4 470ci BBC 700 HP.... D60/14bolt 205/465 http://profile.myspace.com/index.cfm...ndid=127691959 |
08-11-2007, 12:23 AM | #2 |
Re: Did I fry my dist???!!!
don't know, but ttt for you
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD Click here to support the board Philippians 4: 6-7 |
08-11-2007, 12:27 AM | #3 |
Remove module and take to Autozone ,etc. and the can check it. If you have one out of another, try it.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
08-11-2007, 01:25 AM | #4 |
is the roter even turning? you said it turns over to easy. sounds like maby the timing chain let go
common sense isn't so common anymore |
08-11-2007, 03:33 AM | #5 |
you fried the coil, happened to us on our old race car once, had the external coil and we had to weld a bit well it fried the coil in the process, put in a new coil and it was fine and we always took the coil out after that, havnt had any problems with the new car and the hei dizzy though
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
08-11-2007, 04:21 AM | #6 |
coil or module.
08-11-2007, 07:24 AM | #7 |
14 volts sounds to high you would want it about 12 volts
08-11-2007, 09:13 PM | #8 |
I took a stock HEI distributor from another truck...slapped it in...got the timing close and it runs fine now!!! I'm getting ready to do more welding on it tonight.....will I be OK just disconnecting the battery??? Or should I disconnect the dist also??
thanks for your responses. A......
08-11-2007, 09:25 PM | #9 |
Spanked once
Put the ground where you are welding!
08-11-2007, 09:34 PM | #10 |
I did last time......I think something wierd is going on. I don't think it was the welding due to the fact that it started right up and drove back in when I was done. Has anyone heard bad things about ProComp distributors off of ebay??? I'm gonna disconnect everything anyway just to be safe.
thanks, A......
