Old 08-13-2007, 09:18 PM   #1
'68 longbed
'68 longbed's Avatar
anybody try to change hinge pins??
In the future I'd like to get new doors and new hinges. but in the mean time it appears that the pin (at least the top hinge) would be difficult to remove without cutting it as you move it up.
I'm thinking of doing just that but not sure if it will work to try to put some aftermarket pins in their place, somting in the "help" section at the parts stores.
am I correct to assume that these hinges are meant to be replaced as a whole?
it's getting to the point that i'm slamming the door alot to get it to close.
thanks for your help!
"spiiiider pig, spiiiiider pig, does whatever spiiiider pig does. "
'68 longbed is offline   Reply With Quote
Old 08-13-2007, 09:36 PM   #2
Bowtie468
Bowtie468's Avatar
Re: anybody try to change hinge pins??
You will need to remove the door from the truck and also the hinges from the doors. Some pins will come out easily while others can be pretty stubborn. Remove them and clamp them in a vise to drive the pin out and replace the bushings. I'm sure you'd prefer to leave the door on the truck, but you'll have to re-align it anyway. Good Luck !!
Chris
click here to see my buildpage
http://67-72chevytrucks.com/vboard/s...d.php?t=394656
1979 C10 Silverado Big10 SWB
Factory 454/400
Cardinal Red/Santa Fe Tan (original paint)
1969 Camaro X44 LS swap
1968 C10 SWB Fleetside (SOLD)
468BBC MultiPort TPI / Dynamic EFI P4
Black/Black
1963 Nova SS convertible (SOLD)
194 I6/ PowerGlide
Bowtie468 is offline   Reply With Quote
Old 08-13-2007, 10:01 PM   #3
'68 longbed
would it help to use a marker or somthing to trace the location....or am i totally gonna' have to start from scratch?
Old 08-13-2007, 10:27 PM   #4
Bowtie468
Bowtie468's Avatar
Yes, i'd mark the hinge location both on the door and also on the door pillar. This should have you pretty close, unless..... someone has already made adjustments to compensate for worn pins/bushings.
On a side note... Where in Mississippi are you located ?
Chris
Factory 454/400
Black/Black
194 I6/ PowerGlide
Old 08-13-2007, 10:56 PM   #5
jhow66
jhow66's Avatar
Drill a small hole thru hinge into door. When you put door back on just stick the bit into hole and tighten the bolts. Buy new striker plates and use these to align door as they adlust up and down and in and out. (if yours are worn out)
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
Last edited by jhow66; 08-14-2007 at 02:20 AM. Reason: change spelling and added something
jhow66 is offline   Reply With Quote
Old 08-13-2007, 11:26 PM   #6
'68 longbed
great info thanks ya'll!
Old 08-14-2007, 12:15 AM   #7
Fastfun
Fastfun's Avatar
Check out this article : http://www.earlyclassic.com/tech.asp...le%20Rods%20P9
Fastfun is offline   Reply With Quote
Old 09-08-2007, 09:37 PM   #8
tcs81281
i bought new bushing and pins for all 4 hinges for my 69 from lmc, you will see a big difference with new bushing, mine had plastic bushing for some reason, the kit from lmc had brass bushing, the hinges are tight and not sloppy like before.
69 c10 shortbed, fullroller 383
shaved markerlights/doors,20inchrims,700r4tranny
www.flickr.com/photos/tcs81281
tcs81281 is offline   Reply With Quote
