72 pickup brake pedal goes to floor
Ok,(72 disk/drum) try to make this short, bought truck knowing it had rear wheel cylinder leak, assuming this was also related to pedal, I have since replaced rear wheel cylinders and brake shoes. I have bled and bled these things (all 4 corners), but no change in pedal, with little resistance it just goes to the floor. I'm new to this site, but I would appreciate any advice. Things I have checked from reading other post. Brakes are adjusted so drums barely go on, combo/poportioning valve button(?) pushed in., and bled the @#it out of them.
![]() Join Date: Sep 2005
Re: 72 pickup brake pedal goes to floor
master cylider has gone bad
Will it run today?
I recently had a similar problem. No leakage anywhere, but the brakes just kept getting worse. Finally pulled the MC and found that it was leaking back into the booster. Replaced the MC and all is well again.
Good luck!
Jaws, the 1971 Chevy Cheyenne Longbed. She's big, grey, and has an insatiable appetite! |
if it is leaking into the booster always replace the booster
Thanks guys, I put it on yesterday and their is a difference now I just need to re-bleed all four corners.
just clamp the pin on the combination valve like it says in the service manual and the bleeding will go smoothly
![]() Join Date: Dec 2006
Make sure you bleed the new M/C as per the instructions that usually come with one. There's a cheap little kit you can buy for like $4 with hoses and clips that make it really easy too.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme. |
chrome makes it go FASTER!
good luck and WELCOME to the board. Remember WE LIKE PICTURES !!
She can't cook and she won't clean. But she looks good in a skirt and she brings me beer. She can stay for now. EDIT:: But she left me anyway, So forget her. 1962 GMC Stepside V6 4 speed My rolling resto thread http://67-72chevytrucks.com/vboard/s...d.php?t=324226 My old farm truck http://67-72chevytrucks.com/vboard/s...=1#post3465005 |
