Old 08-14-2007, 09:54 PM   #1
muddpile
muddpile's Avatar
72 Lower Trim, Questions
I'm getting closer and closer to the day I order my new lower trim for my 72LWB, and the closer I get, the more I wonder how I'm going to go about installing it. Here's my questions:
-I see LMC have the whole kit for $300 with clips. Is it the same quality as anyones? I'll be doing black.
-I see they also sell the matching tailgate band I need and the letters. Does the band come with the letters or do I have to buy them separately?
-What clips does the kit come with, or better yet, what clips are reccommended use?
-What order do I put the trim on in? If there are nuts that need to go on, some can't be reached with panels on, which is why I ask.
That's about it. Thanks!
muddpile is offline   Reply With Quote
Old 08-14-2007, 10:06 PM   #2
MT1972cheyenne
MT1972cheyenne's Avatar
Re: 72 Lower Trim, Questions
The lower trim can all be installed with the panels on. I would highly recommend using the clips with nuts! They pull in tight a lot better. You do have to have the inner door panels removed to do it. If you didn't already have the holes, I would recommend getting the diagrams from the builders guide for hole placement. If you don't have a builders guide, you should get one from LMC or ?? Also, someone on here will scan the pics that you need until you get your own guide. I can't remember who, though.
MT1972cheyenne is offline   Reply With Quote
Old 08-14-2007, 11:16 PM   #3
Andy4639
Old member
Andy4639's Avatar
I have two sets of this trim for a LWB with the clips. I'm not going to use it. I'm having mine welded up altogether upper & lower. I will make a great deal on it if your interested in it. I have extra clips also.
MT1972cheyenne,
What is this about the mounting holes? Curious even though I'm not going to use mine, I haven't ever herd about where the holes should be drilled. I just drilled the hole and put the clip where it needed to be.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 08-14-2007, 11:29 PM   #4
Billla
Billla's Avatar
Originally Posted by Andy4639 View Post
I have two sets of this trim for a LWB with the clips. I'm not going to use it. I will make a great deal on it if your interested in it.
PM Sent
Billla is offline   Reply With Quote
