Old 08-15-2007, 03:09 PM   #1
truckn'
truckn''s Avatar
Unhappy Help!!!
65 gmc 110 please tell me what exactly these are and what gets wire to them. electrically my new project is a nightmare, headlights, taillights, blinkers, but have to remove all the "rigging" that has been done over the years by others before I can continue. any help would be greatly appreciated.
Thx and desperate
Truckn'
truckn' is offline   Reply With Quote
Old 08-15-2007, 03:59 PM   #2
slorio
slorio's Avatar
Re: Help!!!
The wiring in your GMC is different from that in Chevy's. I would suggest that you visit the GMC site at:
http://6066gmcguy.org
They have a section on electrical that may be of help. If you check with the moderator, Jolly Goodfellow, he also has a scan of the GMC wiring diagram that he could e mail to you that would be helpful as well.
Regards,
Steve
slorio is offline   Reply With Quote
Old 08-15-2007, 04:49 PM   #3
rodnok1
rodnok1's Avatar
Re: Help!!!
First pic is horn relay and regulator, the main power feed goes through the horn relay(just a terminal). It looks exactly like the wiring on my Chevy by the way...
here's a link to some wiring diagrams in color I did last year.
http://67-72chevytrucks.com/vboard/s...d.php?t=193429
2nd pic of headlight dimmer, you can tell the wiring has been modified to say the least.It looks like somebody hacked the wiring off at the bulkhead connectors and just routed new wires where ever they could. You can get new terminals at Napa and go back to stock connectors. Mine was soo bad when I got it, I had to redo every wire exect the fuel sending wire.
64 Panel Rebuild Pics
Clutch Replacement and Borg Warner T10 Trans Rebuild
64 Panel 1/2 Ton
350cubes/400hp
BorgWarner t-10
3:73 Auburn Posi
rodnok1 is offline   Reply With Quote
Old 08-15-2007, 05:43 PM   #4
hewlett2002000
hewlett2002000's Avatar
Re: Help!!!
ok seeing as i have made up a complete custom wiring diagram for my custom harness i am going to make and i have also installed a painless harness in my truck i think this is a stupid question but i have to ask because i dont know. what exactly does the horn relay do and when i make my custom harness do i have to have it? i mean does it cut down voltage or what?
thanks,
John
Respect:
1. A feeling of appreciative, often deferential regard; esteem.
2. The state of being regarded with honor or esteem.
3. Willingness to show consideration or appreciation.
When you fail to show consideration to others values you are showing disrespect.
hewlett2002000 is offline   Reply With Quote
Old 08-15-2007, 11:12 PM   #5
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Re: Help!!!
thanks,
John
The horn relay should be in the block of that Painless kit.
John
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 08-15-2007, 11:19 PM   #6
hewlett2002000
Re: Help!!!
it is but im gonna make mine as simple as possible so im gonna eliminate as much as possible.
john
Respect:
Old 08-16-2007, 10:07 AM   #7
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Re: Help!!!
So your eliminating the horn ?
John
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 08-15-2007, 08:01 PM   #8
rodnok1
rodnok1's Avatar
Re: Help!!!
You need the horn relay only for the horn, you'll have to have power to it for the horn to work. The two terminals are really a power block of sorts(bad idea) under the hood they always rust up and are uncovered so you could short them out. I bypassed these terminals for main power and put in a power terminal that I can run power to my relays to(fan/lights/horn) and over to alt(might go inside first I can't remember).
64 Panel 1/2 Ton
350cubes/400hp
BorgWarner t-10
3:73 Auburn Posi
Old 08-15-2007, 08:18 PM   #9
hewlett2002000
Re: Help!!!
thats what i thought. i just wanted to make sure. im making my custom harness so i just wanted to make sure it wouldent hurt anything to bypass it.
thanks,
John
Respect:
Old 08-15-2007, 10:29 PM   #10
Preacher
New Member
Preacher's Avatar
Re: Help!!!
I had the same nightmare when I picked up my truck. I ordered a Ron Francis fuse panel and a complete bumper to bumper wire harness and eliminated the whole mess. She's nice now! Don't have to worry if she's going to start or not. Thought that was going to be a big job to install, I could've had my preteenage kids do it. Every wire is color coded and labeled every foot. I was amazed at how easy it was to install and it didn't take long at all!
Preacher is offline   Reply With Quote
Old 08-16-2007, 10:48 AM   #11
truckn'
truckn''s Avatar
Re: Help!!!
lots of good info thx alot guys really helps.
Old 08-16-2007, 11:28 AM   #12
hewlett2002000
Re: Help!!!
no im not eliminating the horn. lmao i got an aftermarket horn thats louder so im running that.
Respect:
