08-15-2007, 07:37 PM | #1 |
GEARHEAD
Hydro assist steering questions, PTO option
I found a couple oddities in a junkyard today, and need some educating. I found a 67 GMC flatbed, 1 ton or better. It had this little funky steering set up I hadn't seen before. What I want to know is if this will work on a 4x4 by using a different mounting to the tie rod, and if it is even worth the trouble. I know guys with larger tires use a different steering system, but I don't know if this is the set up. Is this stronger than the normal power assist?
Next was a PTO which was added to a manual transmission. This was on another 1 ton flatbed in the same yard. The only reason I found it was that I came across the manual for it in the glove box, looked underneath and there it was. Is it worth anything? Lastly, a truck had some newer style buckets added in. I have no interest in the seats, but I was wondering if these brackets are original bucket seat mounts. Anyone know? Thanks in advance for any info. HG
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 Long Fleet C/10 72 Jimmy 4x4 (Junkyard Jimmy) HG's Plow Truck '78 K35 Dually Bigass Farm Truck HG's thread of miscellaneous stuff |
08-15-2007, 07:46 PM | #2 |
its all about the +6 inches
Re: Hydro assist steering questions, PTO option
the power steering set up is a stock 67 and late 68 piece. It COULD be an add on, but probablynot. They were better then manual, but normally just leaked and went bad. It was added to a manual steering set up. Very much like early vettes.
08-16-2007, 09:16 AM | #3 |
GEARHEAD
Any opinions on the seat brackets or PTO?
08-18-2007, 11:28 PM | #4 |
The bucket seat brackets don't look like anything truck related. I would say definetly "NO".
I don't know anything aout the PTO so I can't help there either. I hit 50% - sorry I couldn't do better - Bob
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
08-19-2007, 12:44 AM | #5 |
Junior Member
I have seen PTOs on larger trucks being used for such things as driving a hydraulic system for a lift bed.
Danny - Southeast Missouri |
