Old 08-16-2007, 11:03 PM   #1
onebad'65
How to run dual exhaust inside frame?
I've seen someone do this and they had some pictures telling about the supplies needed and tools needed. I know that you've got to cut holes through the cross member but not sure on the size and not sure how to add strength at the cross member. I'm going with 2 1/2 inch exhaust pipe, I'm running long headers, along with 50 series Flowmasters.
onebad'65 is offline   Reply With Quote
Old 08-16-2007, 11:58 PM   #2
Re: How to run dual exhaust inside frame?
I`m not sure what you mean,exactly.I first saw your title and thought,"Is there another way?"I thought you meant between the frame rails like the factory even does it.But,you asked about the crossmember and I think you just mean that.I`d get some 3 or 4 inch tube/pipe and cut the holes for those to fit in.Then,weld them in place.
Old 08-17-2007, 01:29 PM   #3
Frizzle Fry
Frizzle Fry's Avatar
Look at the pics at the bottom of this thread. http://67-72chevytrucks.com/vboard/s...d.php?t=253971
This is what I'm gonna do. I plan to use a 5" holesaw and 5" od 1/4" wall tubing. The trick to using the holesaw is that you need to weld in a piece of scrap across the V-shaped factory gap for the guide-bit. Otherwise there's nothing to keep the saw in place while cutting.
Frizzle Fry is offline   Reply With Quote
Old 08-20-2007, 12:51 AM   #4
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Here is how I did it on my SWB, I'm sure it could be done in a similar fashion on the burb:
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
