Old 09-26-2002, 11:33 AM   #1
kirsten
need i say more
kirsten's Avatar
4 Core Radiator
Cory is going to laugh that it took me this long to check on this...
I have a hole in my rad... I don't think it can be soldered and I have been told that they don't make the rads for our year anymore- is this true? can i get one from the states?
Does anyone know of one close to Vancouver that is in beautiful used shape, if not??
thanks
*1971 3/4 ton GM with a 402 Big Block*
*Sierra Grande Camper Special*
*big block environmentalist-HA*
seaangel@shaw.ca
the creation of a thousand forests is in one acorn~ Ralph Waldo Emerson
kirsten is offline   Reply With Quote
Old 09-26-2002, 11:38 AM   #2
breeh
Recovering 67-72 Addict
breeh's Avatar
I just bought a brand new one in Seattle for $159.00. Here is the link:
http://www.radiatorexpress.com/
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt.
"Friends call me cruzer cuz I like fast cars and fast women"
breeh is offline   Reply With Quote
Old 09-26-2002, 11:45 AM   #3
ckhd
ckhd's Avatar
You can get radiators just about anywhere (at least in the states).
Check this one out. Lifetime warranty.
http://www.radiators.com/price.cfm?c...ookupid=207070
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Why do I own so many Suburbans?
ckhd is offline   Reply With Quote
Old 09-26-2002, 11:47 AM   #4
SCOTI
SCOTI's Avatar
Although it's possible that one particular manufacturer stopped production on these years-- I doubt seriously that 'they don't make them' is an accurate statement. I would try another manufacturer & if that doesn't work I used a late? model ( 78-87 ) elcamino radiator in my beater 68. Dimensionally it fit w/only minor fabrication needed for the lower hose connections because they have different diameters (an easy fix w/parts store aluminized tailpipe sections).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-26-2002, 01:06 PM   #5
lux hauler
Psycho-billy Member
lux hauler's Avatar
You might want to see about having it re-cored (if the rest of the radiator is in good shape). Any radiator shop should be able to do that for you. It might be cheaper to buy a new one though.
'72 C-10
350 w/Lunati Voodoo cam (207*/213*, .437/.454), Performer intake, 625 Road Demon Jr. and Hooker headers.
Support your community, support yourself. Buy local, buy American (or Canadian).
lux hauler is offline   Reply With Quote
Old 09-26-2002, 01:53 PM   #6
johnnyp
Keepin' It Stock
johnnyp's Avatar
I would encourage you to check with a local radiator shop. I buy a lot of stuff mail-order because for a lot of parts that's the only way you can get them. But I always have better luck if I can buy locally - if something goes wrong it's much easier and cheaper to take it back to a local place than deal with a mail order place.
I bought a radiator from one of the mail order places and wasn't happy with the quality. They took it back, but I had to eat the postage. Wound up getting a good quality one at a local radiator shop.
72 Sierra Grande - Maych
Forget about "do it right the first time". Do it wrong the first time to learn how, then do it right the second time.
johnnyp is offline   Reply With Quote
Old 09-26-2002, 10:55 PM   #7
Scrub
Collector of rusty Items
Scrub's Avatar
I bought a new 4 core radiator in Oregon last year for $199.00. I know I can get you one for that price. My parts guy would ship to you if you can't find one. Call Sisters auto parts at (541) 549 8888 and ask for Chris
Good Luck
Scrub
Sisters, Oregon - Home of the Sisters Rodeo.
70 GMC 1,000,000 + miles
72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends.
Scrub is offline   Reply With Quote
Old 09-27-2002, 12:59 PM   #8
nate68
i got an 80's big block radiator and had them change the lower radiator hose angle, fits perfectly
68 short step, 406/700r4, 9" w/discs.
nate68 is offline   Reply With Quote
Old 09-27-2002, 10:39 PM   #9
Jesse 67 c-10
Jesse 67 c-10's Avatar
I bought a rad from a 72 caprice with heavy duty cooling. It has 3 wide cores (like 2 core rads) replaces a 4 core I believe. looks great! It is the exact same height as out rads and fits with the brackets in the outside position, 2" wider than my stock 6 cyl rad. Otherwise exactly the same. It was $200 Canadian, + tax of course, but I saved $100 over buying the same type rad for my truck new. Got it from Parts Source here in saskatoon, in stock. I did lots of shopping, this was the best deal, next was $240 for a good recore, and now I have a still decent 2 core rad kicking around for something else!
Jesse
Edmonton, Alberta, 67 c-10, Long fleet, front disks, 5 lug rear end, 327 with Vortechs, edlbrock manifold, comp cams XE 256, 600cfm carb. Backed by a getrag 5 speed and 1 piece driveshaft.
1993 Dihatsu Hijet Jumbo cab 4x4, currently converting to battery electric power.
Jesse 67 c-10 is offline   Reply With Quote
Old 09-28-2002, 12:08 AM   #10
smitty62
smitty62's Avatar
I just bought a 4-core Modine locally WITH heater return ( a lot of dicount radiators don't have these)----------$144.50.
Stepsides look like real trucks!
Smitty
smitty62 is offline   Reply With Quote
Old 09-28-2002, 12:42 AM   #11
mtdave2
newly minted old timer
mtdave2's Avatar
see, kirsten is so darn hot she is melting holes in things! lol
just order a new one =)
72 c20 longhorn 65k org miles and counting!
69 k10 Suburban
mtdave2 is offline   Reply With Quote
