08-18-2007, 11:17 PM | #1 |
swapping 250 for the 350; frame mounts
Hey guys, I am going to swap my 250 6 cl for a 350 and I was wondering if the frame mounts(for the motor) would work or do I need to buy new ones, and if so, who carries them.
thanks in advance
70' 1/2 ton 2wd 350/muncie m-20/12-bolt rearend Darin |
08-19-2007, 09:09 AM | #2 |
Re: swapping 250 for the 350; frame mounts
You will need the v8 towers (frame mounts). also you'll also need to move the engine foward to the foward mount holes on the frame. This will put your engine in the correct v8 position, this looks better and gives you a extra inch between the firewall and distrbuter otherwise it will not allow you much clearence. do a search, this topic has been covered many times.
71 C10 SWB BLACK AND WHITE 350 CRATE TH350 ENJOY LIFE |
08-19-2007, 08:07 PM | #3 |
ran out of money
the PO of my truck put a v-8 in the I-6 position, yeah it looks set back far but it doesnt have any problems
Modify everything, leave nothing alone!~ |
08-19-2007, 11:59 PM | #4 |
upgrading to an older model
I'm gonna be doing the same thing except from a I-6 292 (doesn't run) to a 307. Are these the "towers" your refering to?
http://cgi.ebay.com/ebaymotors/ws/eB...154172891&rd=1 I've read on here that you also need to move the mounts 3" forward to allow room for the distributer not to be cramped, is this right? I've got a brother-in-law that'll actually gonna do the swap (I'll be assisting) I just want to make sure we have all of the right parts and tricks. Last edited by Brock; 08-20-2007 at 12:00 AM. |
08-20-2007, 12:08 AM | #5 |
Next project: 1970 K10
You CAN run a V-8 in the I-6 position without any problems. My 68 was like this for years until I started the rebuild. I even ran an HEI, installed with no problems. I am moving it into the V-8 position just because I can.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
08-20-2007, 12:29 AM | #6 |
glock is right ... you can run a small block on the I6 towers ... my '67 was that way when i got it and it ran fine.
08-20-2007, 01:22 AM | #7 |
Is there any mod needed down the line (drive shaft, rearend)?
I'm going with a 700r4 from a 3-OTT
68 stepside, short-box, multi-colored (for now) |
08-20-2007, 06:34 PM | #8 |
68 c-10 1/2 ton swb fleetside, 79 GMC Sierra Grande 1/2 ton swb fleetside, 99 Dodge Durango 4x4(wifes ride),53 and 55 chevy trucks(dads trucks ) 54 caddy 62 series 4 door(younger sons ride, aka 54caddy ) 70 caddy 2 door, 89 chevy silverado stepside(older sons rides ) |
08-20-2007, 06:42 PM | #9 |
If you do the factory set up and move the engine forward, yes you will have all the stuff that goes along with it. Tranny lines will be too long, driveshaft will be too short, need to move the tranny crossmember, and the shifter linkage too. All the frame holes were pre-drilled from the factory on mine, so it was just a matter of moving everything and having the driveshaft re-done. I got some generic brake line from Oreillys for cheap and hand formed them as tranny lines.
_______________ Thomas '78 Silverado '74 Monte Carlo '47 Teardrop Trailer East Texas Classics Local Club |
