08-21-2007, 11:36 AM | #1 |
Junior Member
floor pan to rocker?
Can anyone provide pics of how the floor pan connects to the rocker? (62 c10) Mine has new rockers, and some new metal in the floor, but a there's still a gap between the floor pan and the rocker where they didn't finish the job.
Just trying to figure out what it's supposed to look like. Isn't there supposed to be a u-shaped channel along the edge of the floor? Was that a separate piece, or is it all part of the floor pan?
_______________________________________ 62 SWB BBW (under construction) 86 Vette Convertible |
08-21-2007, 03:57 PM | #2 |
Re: floor pan to rocker?
it is supposed to have that u piece. i was looking around for a replacement of just that piece but no luck. because mines rusted out, but everything else is fine, just the "U" piece is rusted. ill snap a pic later and post it up.
John
Respect: 1. A feeling of appreciative, often deferential regard; esteem. 2. The state of being regarded with honor or esteem. 3. Willingness to show consideration or appreciation. When you fail to show consideration to others values you are showing disrespect. |
08-21-2007, 08:56 PM | #3 |
Are you talking about the lip where the rubber door seal attaches to? You either have to replace the rocker, or bend up your own lip, and weld it.
08-22-2007, 04:46 PM | #4 |
Junior Member
The lip is there as part of the new rocker, but there's about an inch gap between the rocker and the floor pan.
08-29-2007, 04:04 PM | #5 | |
60-66 Nut
It's kinda hard to say without a pic, but it sounds like someone didn't correctly place the floor pan
08-29-2007, 05:31 PM | #6 |
Yes it sounds like they aren't installed correct. You should not have a 1" gap betweeen the top of the floor and the bottom of the rocker edge at the lip.
I agree its probably in the floor. It takes a little skill to do body work. I have seen many people attempt it and not get them correct. Some even complain about the fit when it wasn't even installed correct. Anyway if you can post some pics maybe we can see what is wrong. Mike |
08-30-2007, 09:33 AM | #8 |
Junior Member
right, it's rusted. the new rocker has been installed, but there's a gap that hasn't been finished between the rocker and the floor pan. So there's a patch panel for the edge of the floor pan to the rocker? Let me know where I'd find it?
_______________________________________ 62 SWB BBW (under construction) 86 Vette Convertible Last edited by 53lowdown; 08-30-2007 at 01:52 PM. |
08-31-2007, 03:48 PM | #9 |
If you are talking about the gap horizontally from the lip to the pan it is normal. While the gap varies a little from truck to truck this is where carpet lays dowin into. Your rear light harness and dome light wires usually run through this channel also. The sill plate lip comes down over the inner edge and covers alot of it.
It looks like your floors may have been glassed to me and may be causing a slightly larger gap. |
