So there I was...
Hi all, I see that this is clearly a "slam'n" type of place, but I would like to be different! Anyone know of a place where I can find replacement front coils that will give me an inch or two of *lift*. I know, I know...it's all about bags, notches, and lay'n frame! Try'n to keep my chin *out* of the dirt though.
![]() The truck is a '69 2WD C10 with leafs in the back. I would like to just get slightly taller front coils but would be interested in any suspension lifts that you guys know of for the truck. Thanks! Last edited by FingerTight; 08-22-2007 at 01:36 PM. |
ROCKWELL 5 TON CLUB !!
![]() Join Date: Oct 2006
Re: On a different note...'69 2WD lift?
1ton big block coils might lift it a small amount.i m not positive on that but sounds like a good answer.
you could use some coil spacers like on a lot of newer trucks,can usually get 1-3" lifts...body lift would be 3 ugly inches,but cheap. well,thats my .02...........except for................ sell it and buy a 4x4,or swap in a solid axle,could even do a straight axle 2wd swap to get leaf springs on the front and lots of lift possibilities. anyhow..
1970 K5 "ON THE ROCKS" PROJECT:500hp 6.0 fuel injected. 2wd sm465 trans,t136 2.5 ton transfercase,5ton rockwells with 9.34 gears,custom wheel disc brakes,full hydro steering20+" OF LIFT AND 67/35/25's..67" tall TRACTOR TIRES.."THE MUD SLUT!!" MY BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=221935 1997 TAHOE,SAS D60 14B,5:13 DISC BRAKES,CROSSOVER STEER,HYDRO ASSIST,42 IROKS HINT:NEW NAME "K5ontheROCKS!" |
So there I was...
Good ideas, I was debating the spacer. Also talked to National Spring in Santee, CA about some custom coils @ $325 a set. http://www.nationalsprings.com/
- Rick 1969 C10 LWB, leafs, 350/700R4, ![]() 2003 Yukon Denali Last edited by FingerTight; 08-31-2007 at 01:51 PM. |
I pulled a Fabtech 4" lift off a 2WD 69 a while back... it's just sitting on my shelf collecting dust. It consists of upper and lower control arms and coil springs. I also have a set of rear leafs off the same truck. The truck never saw the road with the components... and never will! If you're interested in something like this make me an offer.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
#5 | |
So there I was...
- Rick 1969 C10 LWB, leafs, 350/700R4, ![]() 2003 Yukon Denali |
So there I was...
So I am finding some kits for 73 - 87, how is this vintage front suspension different than mine? Any thoughts on whether or not this will work for me?
Get a 2wd suspsension lift for the front coils...73-87 type should work,and just lift the back up using blocks..
#8 | |
So there I was...
Just the info I was looking for, so these coils will work. Any thoughts as to how high I can go before I need to start changing things other than the coils? (arms, ball joints, spindles, etc) I am guessing anything below 2" will be fine but would love to hear from someone who has done it...
I dont know for a fact that it will work so you might ask others that know 2wds...but it should..Worse that could happen would be you need to put a 73-87 crossmember in the front..I dont know if the rear lift kit from a 73-87 will work but since yours has leaf springs in the back,it might.Personally,I'd go for Porterbuilt's set up since you know it will work since it was already on a 67-72.
So there I was...
Thanks again for the replies! Talking to porterbuilt as well...just covering all the options.
![]() Join Date: Aug 2003
i think 2" is the most lift i would do with just coils. any more than that and you start wearing out ball joints. the control arm angles get pretty out of whack.. i used to have 3" lift coils with ball joint spacers and it was a harsh ride. it got better when i got the new a arms. if i would do it again i would use a "kit" similar to what porterbuilt has.
