08-25-2007, 11:27 AM | #1 |
What are my options? Steering linkage issues...
I'm back!!! Not that you guys missed me Had a few month hiatus from the truck because I just had my first son!
Here's my issue that I know is a very familiar one: I sectioned my crossmember 1.5" and now the inner tie rods are JUST skimming the nut on the a-arm ubolt. The only option (besides porterbuilts kicka$$ dropmember) I see is putting a .25 plate between the crossmember and frame. Is there any other tricks I am not thinking of to remedy this problem? Thanks guys! Its nice to be back... Josh |
08-25-2007, 01:39 PM | #2 |
A guy with a truck
Re: What are my options? Steering linkage issues...
Maybe try some different tie-rods. Some of them are a little smaller. Just go to the parts store and pull all the brands they have. I've also heard of flipping the center link, but I couldn't make it work...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
08-25-2007, 01:57 PM | #3 |
I did think about that. I've got all new moog tie rod ends. The inners look pretty darn small as it is. I'll have to check the parts store though just in case. i dont think I'm going to gain enough though just from a different tie rod.
08-25-2007, 02:58 PM | #4 |
use thinner nuts
08-25-2007, 03:03 PM | #5 |
08-25-2007, 07:03 PM | #6 |
I didn't trim mine down because they aren't that thick to begin with IMO. I would have had to remove 1/2 of the nut to have >1/16" clearance.
Jlaird..... Mine was just a 1 3/8" notch & I had to add the c.member 'shim' like you're thinking. I also removed the reinforcement 'tab' where the u-bolt goes through the crossmember (basically.... it's the washer on top) & cut it in half. I reinstalled one half of it for just the inside part of the u-bolt. I threaded the nuts down on the u-bolt & trimmed off all exposed threads above the outer nut. This allowed the outer nut to tighten down on the u-bolt as much as the inner nut, yet it's about 1/8 ~ 3/16" shorter on the outer side (w/o sacrificing the intergrity of the nut). I also made sure I was using the later model 9/16" u-bolts vs. the originals (68 drum brake 1/2" u-bolts).
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 08-25-2007 at 07:06 PM. |
08-25-2007, 08:08 PM | #7 |
scoti,
I was hoping you would chime in. I remembered you used the shim. Thanks! One question, when you say later style u-bolts, I'm assuming you are referring to 73-87?? How thick are your shims? Last edited by jlaird; 08-25-2007 at 08:09 PM. |
08-25-2007, 11:31 PM | #8 | |
I had read where the max was 1.5" for a 'trouble-free' notch so I thought I would give myself some fudge room & only go 1 3/8". To my suprise, that didn't even work & I had to go w/the 1/4" shims to give myself >1/8" clearance on the steering linkage. You can also see the corner of the motor mount stanchion in the 'shim' pic.... they also had to be spaced 1/4" to keep everything consistent.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 08-25-2007 at 11:33 PM. |
