08-28-2007, 12:06 AM | #1 |
Steering Colum question
Hey fellas was wondering if you guys had any insight on a good colum to replace my stock one, maybe a tilt colum and or aftermarket one. Also and suggestions for rebuild kit and new wheel/hub combo. My current one is pretty loose and also since I switched to a floor shifter Im not dig'n the old gear selector and stuff.
08-28-2007, 12:44 AM | #2 | |
Re: Steering Colum question
http://www.truckandcarshop.com/trucks60_72/t60_049.html Upper and lower bearings are easy to do, and all my slop disappeared. |
08-28-2007, 02:42 AM | #3 |
Thanks rob, thats what I was looking at getting...and just re-spraying the column. Probably save cash that way too!
08-28-2007, 10:58 AM | #4 |
I forgot to tell you if you want to get rid of the column shifter, you can always pick up a 4 speed floor shift column.
08-28-2007, 06:21 PM | #5 |
Is that a factory automatic column you have? Hmmm. Those are hard to find around here. Joe
08-28-2007, 07:32 PM | #6 |
i got a factory auto column in my shop in not using. just for info......
Respect: 1. A feeling of appreciative, often deferential regard; esteem. 2. The state of being regarded with honor or esteem. 3. Willingness to show consideration or appreciation. When you fail to show consideration to others values you are showing disrespect. |
08-28-2007, 07:34 PM | #7 |
yah it is but i took off the gear selection on it....I think Ill just rebuild this stock one, Truck Shop has all the parts for dirt cheap
