08-28-2007, 12:12 AM | #1 |
IFS front
Been looking at IFS front ends in the magazines. I see they offer stock or 2" drop spindles. Is the stock the original truck height because it seems it will still be much lower then stock suspension? I want my truck lower in the front but not slammed.
08-28-2007, 02:36 AM | #2 |
Re: IFS front
Stock is the stock height for that particular spindle. With the 2-1/2 in dropped spindle the truck would sit 2-1/2 in lower w/o cutting the springs.
Probably the best thing would be to talk to the tech rep from the mfg you want to buy the cross member from and give info such as I have this model of truck= I want to run this tire and wheel combination= I am going to run this engine and trans combination= I want the truck to ride and sit at this height= Then see what they suggest. |
08-28-2007, 09:00 AM | #3 |
Re: IFS front
Yeah and I would recommend FatMan Fabrications, just got mine for the '52 last week, went coil-overs and 2.5 drop spindles. If you go coi-overs you can adjust ride height a little.
1947 International KB-1 1957 Chevy Bel-Air riding low 1962 swb fleetside 2002 Chevrolet Silverado 7-inch lift on 35 Daily driver 2016 Chevy Tahoe Better halves ride |
09-03-2007, 02:40 PM | #4 |
Re: IFS front
Another one for AD trucks is
Industrial Chassis Inc These use a 86 to 90 Dodge Dakota bolt ons! Lets try that again, Industrial Chassis Inc
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 Last edited by solidaxel; 09-03-2007 at 03:34 PM. Reason: error |
09-07-2007, 12:20 AM | #5 |
chevy only
Re: IFS front
09-07-2007, 12:29 AM | #6 |
chevy only
Re: IFS front
What size tires and wheels are you going to run? you may think about that before you lower your truck. and how you want it to sit
09-05-2007, 03:35 PM | #7 |
Re: IFS front
I remember reading somewhere that an IFS will lower the truck 3-4 inches w/o lowered spindles.
09-05-2007, 06:13 PM | #8 |
Re: IFS front
I guess a good measurment would be the center line of the spindel to the bottom of the frame at the spindel, with a solid axle and the Mll or any aftermarket IFS. They should be measured with the same height tires
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 Last edited by solidaxel; 09-05-2007 at 06:17 PM. |
09-06-2007, 03:36 PM | #9 |
Re: IFS front
heres an ifs with 2" drop spindels. i have arround a 1/4 inch clearance from the concrete to the oil pan. i think i could "lay" crossmember if i really wanted to....
Greg 1953 chevy 1/2 ton 5 window, chevy 350 330 horse 700r tranz, lowering spindels mustang 2 frount. ford 9", airbags on 4 corners . purchased in 1983 for $325 while in high school http://67-72chevytrucks.com/vboard/s...=215079&page=5 |
09-07-2007, 02:58 AM | #10 |
Re: IFS front
how much of a difference would you see if you used coil overs instead of a airbag set up? awsome truck by the way.
Anthony |
09-07-2007, 02:07 PM | #11 | |
Re: IFS front
GT
09-07-2007, 09:15 PM | #12 | |
Re: IFS front
Anthony |
09-30-2007, 10:45 PM | #13 |
Re: IFS front
Thanks Anthony more the compliment. Think of the money I will save on polish!!
09-30-2007, 11:15 PM | #14 |
Re: IFS front
yeah no kidding. I`ve been trying to get this old truck from a lder friend of mine. It`s a 47-53, not sure on the year, but it`s in a better shape than yours is but i wish it was in the same condition. Is that crazy or what? I love the patina look especially when it`s earned.
Anthony |
10-05-2007, 05:37 PM | #15 |
Broke Club =(
Re: IFS front
but when we are talking about these systems, which are the most user friendly? i have been looking around for a set up myself but i cant come to pick one. when i say user friendly i mean, easier to install.
10-05-2007, 05:49 PM | #16 |
Re: IFS front
Easiest would probably be bolt-in from someone like RB's Auto. Other than that there pretty much all alike IMHO as far as ease of installation goes.
10-07-2007, 01:42 AM | #17 |
Re: IFS front
This is my wife's '47. Used a Fat Man Fab IFS w/stock spindles & took out 2 coils. Front bumper sits about 3 5/8" off the concrete. May go with coilovers to get a bit more hight out of it.
Cleverly disguised as a responsible adult |
10-16-2007, 04:15 PM | #18 |
Broke Club =(
Re: IFS front
i know its more money in the long run but, can u buy a crossmember then just add you're own upper and lower control arms? or is there a year of car where i can just get them and weld them to a mount? i dunno just checkin my options, havin a hard time findin a deal.
10-16-2007, 06:20 PM | #19 |
Re: IFS front
All the aftermarket manufacturers sell the crossmember seperately & you can either buy their hub-to-hub kit or use paieces from 74-78 Mustang II's. I did the hub-to-hub as I wanted to be able to not use the strut rod that the stock MII suspensions use.
10-16-2007, 06:39 PM | #20 |
Re: IFS front
there are deals out there... Keep hunting.. I picked up a new TCI mustang II kit brand new in bare steel for 800
