Old 08-28-2007, 06:33 PM   #1
kombreeze
Drop Springs or Spindles
Well I'm ready to drop the truck and give it a more cruiser appearance. Who's running just springs? The thing is I'm running 275/60/15 tires on some Chevy Ralleys front and rear. I want to be able to still load a few things from time to time but want the truck to have a good stance. The other thing is I'm still running drums all the way around but I don't really drive my truck all that often or fast for me to upgrade to disk yet (new drums and brakes were just installed prior to purchase). I"m wondering just for cruising and 20 min rides on the freeway what is recommended......every other day driver... i'm not racing just want to have a clean rat rod truck that can haul things from time to time....Pics if you got them will be helpful too.
68 chevy truck
70 Datsun 510
2000 Nissan Sentra
2006 Toyo Camry
Soon 69 Firebird 400 Convertible I'm getting it back
Soon Trailblazer or 4 Runner
kombreeze is offline   Reply With Quote
Old 08-28-2007, 07:19 PM   #2
67cst
i love summertime
67cst's Avatar
Re: Drop Springs or Spindles
here is mine, its got 4 inch springs in the front, they are okay but im gunna go with a 2 inch spindle and 2 inch spring this winter when i have it parked, it has 275 60 15s on ralleys too so that will give you and idea what the set up looks like
1967 shortbox stepside Chevy, 365 hp 327, th400.
GLOVE BOX LIGHTS FORSALE, click link for info
http://67-72chevytrucks.com/vboard/s...d.php?t=273724
67cst is offline   Reply With Quote
Old 08-29-2007, 01:36 PM   #3
northerngmc
northerngmc's Avatar
I am also pondering lowering my 69 GMC with drums.......
Why are you changing from 4 inch springs to drop spindles and 2 inch springs? What do you hope to gain or change?
Blaine
59 GMC 9314 a.k.a. Whoopee
68 C20 50th Anniversary a.k.a. The Rat
http://www.flickr.com/photos/northerngmc/
http://www.members.tripod.com/P-wee/index_032.htm
1.61803 is one H of a lot better than 3.14159, no really it is!
northerngmc is offline   Reply With Quote
Old 08-28-2007, 07:20 PM   #4
68 P.O.S.
My setup sounds pretty much like your's. I have 3" & 5" drop springs w/ drums all around. I also have the same size tires as you on all 4's. I plan on adding dropped spindles as well once I get discs on the front.
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 08-29-2007, 01:38 PM   #5
northerngmc
I will ask you as well.....
Why are you changing from 3 inch springs to drop spindles and 2 inch springs? What do you hope to gain or change?
Blaine
Old 08-29-2007, 03:24 PM   #6
fatboys69
fatboys69's Avatar
Just finished installing 1.5" drop tubular control arms on my 69 and already had the 3" drop springs in it, gotta change them out to 2.5" drop spindles and 1" drop springs to be able to get the geometry correct. I love the way the drop springs ride, just gotta "correct" a few issues, will be doing that in the next few weeks. I achieved the stance I wanted without bags, and am running
255/70/15 w 15x8 TT2's on front and 285/70/15 w 15x8 TT2's on rear with 4" drop springs, 1" blocks, and adjustable trac bar. Handles like it is on a rail !!!!
fatboys69 is offline   Reply With Quote
Old 08-28-2007, 07:35 PM   #7
ChevyDude
Lil' Red has 2" drop front springs with ECE 2.5" drop spinds...and 4" drop rear springs. Chrome ralley's and derby caps.
Alex
1971 Lil' Red 350 SBC 700R4
ChevyDude is offline   Reply With Quote
Old 08-28-2007, 08:26 PM   #8
Scott68-93-97
Scott68-93-97's Avatar
If you want to keep the stock ride buy spindles if it were me cut a half coil off the springs and put a 2.5 drop spindle on ( cutting the spring a half coil will make it a 1 in drop but will increase your spring rate 10% which I think rides a little better than stock) this will give you a nice ride, handle better and not mess up the geometry of the suspension much (1 inch difference in a arm geometry) then throw a 4 in spring in the back if you still gonna load stuff unless you want it level throw in a 5 in rear spring and add a air helper system in the rear to keep it level when loadn er down
1968 Short Fleet 350/700r4
http://67-72chevytrucks.com/vboard/s...d.php?t=249435
1997 Bagged XtdCab Vortec350/4L60e
http://67-72chevytrucks.com/vboard/s...44#post2286144
1993 XtdCab Longbed 4x4 6.5Turbo/NV4500 "Daily Driver"
1985 Toyota XtdCab 4x4 22re/W-56/Dual T-cases, Doug Thorley Header, Homebrew front and rear spring packs, Tons of Mods to suspension and drivetrain, 35" boggers, coming soon ARB's and 5.29's, Possible 4.3/700r4 swap
Scott68-93-97 is offline   Reply With Quote
Old 08-29-2007, 12:25 PM   #9
kombreeze
Thanks fellas for your input on it. Are there any more out there with pics oh and how difficult was it to swap just the springs, what should I anticipate in addtional cost other than springs and shocks....
68 chevy truck
70 Datsun 510
2000 Nissan Sentra
2006 Toyo Camry
Old 08-29-2007, 03:32 PM   #10
klownkar
Junior Member
klownkar's Avatar
When I First Did My Truck I Ran A 3 Inch Drop Spring In Front And 4 Inch Out Back. It Wasn't Bad For A College Guy On A Budget. I Didn't Like The Ride All That Much So I Swapped To A 2" Spindle And A 1" Spring Up Front. Like An Idiot Though I Switched Out The Rear Coils For Leafs. Been Kicking Myself For That For About 10 Years. The Reason I Swapped Rear Suspension Was You Can't Haul Anything With Lowered Rear Coils
70 chev c-10 long bed (prepping for second go round and short bed)
klownkar is offline   Reply With Quote
