Old 08-29-2007, 01:08 AM   #1
wibilly
wibilly's Avatar
lights
i'm finaly getting my truck done and having lighting problems.i have head lights, turn signals and 4 ways but no tail, stop, park,dome and instrament panele lights the gauges all work as do the turn indicaters and brake warning lights. are the side markers suposed to work with the signals or parking lights?
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 08-29-2007, 05:29 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: lights
those are all on the same fuse, check the fuse, if it's good, then it's time to check fuse connections and harness testing time.
Old 08-29-2007, 07:34 AM   #3
72armyswbtruck
72armyswbtruck's Avatar
Re: lights
Man better you then me I can't stand electrical stuff
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 08-29-2007, 08:34 AM   #4
68gmsee
Active Member
68gmsee's Avatar
Re: lights
After checking what has been mentioned above and still not working, check the connector at the instrument panel itself. If you've had it off, the lands on the printed circuit board on the instrument panel may get damaged when you plug the flat connector in and they get shorted. (Item 36: http://www.lmctruck.com/icatalog/cb/0051.asp )
Another thing to check is the brake switch at the brake pedal.
68gmsee is offline   Reply With Quote
Old 08-29-2007, 03:03 PM   #5
Longhorn Man
Re: lights
Originally Posted by PanelDeland View Post
Side markers are supposed to work with the parking lights.Turn signals and brake lights are the same...
turn signals and brake lights are the same filiment on the bulb, but not the same fuse. Everything he listed is on the one circuit/fuse.
Old 08-29-2007, 10:52 AM   #6
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: lights
Side markers are supposed to work with the parking lights.Turn signals and brake lights are the same.In the FAQ's is a post either with schematics or a link to them.They may help some.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
