Old 08-29-2007, 06:35 PM   #1
bossrod
vapor lock
I think I experienced a vapor lock the other day. Truck just shut down, started briefly and then shut down again and wouldn't refire. Went out today and it fired right up. I'm running headers on the vehicle and was in some bumper to bumper traffic just prior to the shut down. This is the only time it has happened in the short three weeks I've had it back on the road. Were there any shields on these trucks, 72 C-10, over by the gas line? Any suggestions on how to make sure this doesn't happen again? Would greatly appreciate any ideas as I have already searched the forum for answers.
bossrod is offline   Reply With Quote
Old 08-29-2007, 07:59 PM   #2
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: vapor lock
Wow, vapor lock. Been a long time since I have heard of that happening.
Check the placement of your fuel lines. Getting them away from the heat is the key to solving this problem. I have seen people put clothespins on the fuel line under the hood to act as a heat sink. Don't know if it worked or not, but if it made the owner feel better, so what. Make sure your fuel line isn't laying on the intake and that air can move around it. I don't know if any of this will help and they are only suggestions. I just know that heat is the culprit. Make sure your cooling system is in good shape. A lean mixture at the carburetor will also cause your engine to run hotter. Sometimes, headers can lead to a leaner mixture.
Member Nr. 2770
Old 08-29-2007, 08:00 PM   #3
68gmsee
Active Member
68gmsee's Avatar
Re: vapor lock
Other than some sort of heat shield to protect the lines from the heat, I'm not sure what else you can do. A friend of mine used "wooden clothes pins on his car a long time ago. He swore it helped his problem. He had several along the fuel line going to the carb.... Looks dumb but, some will swear by this. It may be a way to test to see if that's your problem.
I've never had any problems with vapor lock on any of my vehicles. I would imagine the line would have to be by a very hot part of the engine like the headers or something.
Just make sure that it's not something else such as filters, ignition, carb adjustments, etc.
68gmsee is offline   Reply With Quote
Old 08-29-2007, 10:03 PM   #4
hemihead
hemihead's Avatar
Re: vapor lock
I have had this happen 3 times this year. Leave the truck sit and it restarts. My line runs bythe headers and rests on the block on its way to the carb.
I definitely will re-route what I can and maybe some header wrap as well.
1967 SWB C-10, BBC 454, T400, 3.73 posi, 20" Coys
1972 K5 Blazer, SBC 400, 4 spd, 3.73, 6" lift, 35" mud grapplers
2011 Sierra Denali HD, 6.6 L Duramax, RBP 96R rims, leveled and Nitto trail grapplers,
2009 Acura MDX
hemihead is offline   Reply With Quote
Old 08-29-2007, 09:43 PM   #5
Shyguy
Junior Member
Shyguy's Avatar
Re: vapor lock
I had a similar problem years ago with a motorhome. I installed an electric fuel pump real close to the gas tank and it solved the problem.
A friend of mine had dual exhausts put on his motorhome which caused an oven effect between the frame where the gas line was causing vapor locking. He solved the problem by running the gas line on the outside of the frame.
Danny - Southeast Missouri
Shyguy is offline   Reply With Quote
Old 08-30-2007, 06:36 AM   #6
bossrod
Re: vapor lock
Thanks guys for all the ideas, hopefully I'll overcome this problem real quick. My engine isn't overheating as I have twin SPALs and it pumps a lot of air. The header heat problem is most likely what needs to be addressed. I'll check also if the filter is on the manifold and make a braket to solve that.
Again thanks for the info, this forum rocks!
Old 08-30-2007, 11:19 AM   #7
72freak
Rottenwood Garage Member
72freak's Avatar
Re: vapor lock
Cary a bottle of water with you......normally cool water poured on the fuel pump will unlock it. Its worked for me MANY times. And yes......the clothes pin thing has been done here also untill a heat shield was fabricated.
2004 Chevrolet Suburban C1500
2001 Chevrolet 2500HD Crew 6.0
1999 Harley Davidson Electra Glide
1972 Chevrolet C-20 Custom Camper "Dump Truck"
1972 Chevrolet C-20 Suburban "Big Green"
1969 Chevrolet C-50 Wedge Hauler "Leonidis"
1966 C-10 2x4 short fleet 327 4 speed "Race Truck"
1952 Plymouth Cranbrook "Rican" (my grandfathers)
1931 Ford Model A Coupe "Black Beauty"
1930 Ford Model A truck "Club Cab" 4x4
Rottenwood Garage and Speed Shop.....where everything must be racy!
It's not just a hobby..It's a LIFESTYLE!!!
Thanks for nothing Barrett-Jackson
You cant fix stupid or teach accountability!
Time wasters, looky Lous and tire kickers are everywhere!
72freak is offline   Reply With Quote
Old 08-30-2007, 06:39 AM   #8
72armyswbtruck
72armyswbtruck's Avatar
Re: vapor lock
Never heard of clothes pins being used before
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 08-30-2007, 09:06 AM   #9
68gmsee
Active Member
68gmsee's Avatar
Re: vapor lock
Not surprised. I was raised in the country looong time ago when people tried everything. If it worked, they would pass it on.
Where I grew up, baling wire, duct tape, lighter fluid to inflate tires, soap and rubber fuel line patches for holes in the fuel tanks were not just stories. Old farmers and ranchers and some of us actually used these methods...
Old 08-30-2007, 10:31 AM   #10
Shyguy
Junior Member
Shyguy's Avatar
Re: vapor lock
I was born on a small farm in the mid 40's. Most of our farm equipment was held together by baling wire.
My first vehicle was a '56 F*rd pickup and the exhaust hangers were all baling wire.
I remember when I was a kid we had a '51 F*rd car that would vapor lock and instead of fixing the problem my dad would carry water to poor on the spot when it vapor locked.
If any of you ever read the book "The Painted House" you will get a glimps into what it was like back in the those days where I grew up.
Danny-Southeast Missouri
