New engine running bad
I just got done putting a stock 350 crate motor in my truck and I started it up. It is reving really high and the oil pressure gauge goes thru the roof. The only upgrade it has is the HEI distributor. I am wondering what I can do to stop the engine from reving so high. I don't have a tach yet so I don't know what the RPMs are at. It is almost like I have my foot on the gas and I am trying to pass somebody on the freeway. Any ideas??
Lemme show you something!!
Re: New engine running bad
Is it a new carb as well? If so, double check the idle speed adjustment. Also check the timing- too much advance will boost up the rev's. Check throttle linkage to make sure it's not hung up somewhere.
'67 CST-10 LWB ("Crusty") SOLD '67 GMC SWB ("Murdock") 2000 K1500 Suburban ("Betty") '95 BMW 325i ("Joy") |
I backed the idle speed screw off.....nothing happened. Linkage isn't stuck...guess timing is next.
Carb is a quadra jet...not sure about the linkage but I have a regular pump nothing special.
What kind of carb? What kind of gas feed linkage?
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
Is carb new or off your old motor? Also check your fast idle screw.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer Last edited by jhow66; 08-31-2007 at 10:29 PM. |
What about a vacuum leak?
1970 Chevy C10 "Under Construction" ![]() 2002 Chevy S10 V6 ![]() |
Carb is new to me but not a new one
All vaccum lines are new and there are no open holes........Going to check the timing more later.....
Just wanted everyone to know that I found the problem this weekened. I was missing the sping that holds the throttle forward on the right hand side, so when I stepped on the gas the throttle would not return to the closed position like it should. Thanks for all the support and knowledge. It is running good for now.
