Old 09-01-2007, 02:01 AM   #1
gringoloco
A guy with a truck
gringoloco's Avatar
What do I have here???
Started stripping the top today for some much needed TLC. Plans are to repair all cracks, paint, and intall new weatherstripping/seals/domelights, etc before fall rolls around. Man, rebuilding this thing is $pendy! GMCPaul is making a killing off me...
I started sifting through my parts to make sure I had everything for the rebuild, and noticed my hatch struts look kinda funny. I don't think these will work as-is. Do I need a different end, or new struts altogether? Any one know what these are? Suburban? I'm lost.
Also, does anyone re-pop the dome light harness and panel? You know, the one that says "Disconnect before removing top" or something along those lines, and the harness from the fuse box to that plate.
Thanks -Chris
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 09-01-2007, 08:03 AM   #2
Kool K5
Kool K5's Avatar
Re: What do I have here???
Well thats the same thing thats on my Blazer, so it doesn't look like anythings missing.
Evan
70 Blazer 4x4 305/sm465/np205
80 Buick LeSabre Limited
72 Honda CB350F
77 Honda Cb750K
00 Ducati Monster M900ie
Kool K5 is offline   Reply With Quote
Old 09-01-2007, 09:36 AM   #3
hgs_notes
GEARHEAD
hgs_notes's Avatar
Looks correct to me also.
hgs_notes is offline   Reply With Quote
Old 09-01-2007, 11:16 AM   #4
crzngmychvy
"1972 C5"
crzngmychvy's Avatar
Same here... Look ok
- 72 2wd Blazer ...sold...
2wd Blazer Page
crzngmychvy is offline   Reply With Quote
Old 09-01-2007, 01:15 PM   #5
71swb4x4
71swb4x4's Avatar
The angle iron type bracket is wrong.
IIRC both ends had brackets that are similar. The top brackets should look like the bottom ones. They should be like the smaller ones with the two mounting holes.
The struts themselves are correct, just the mounting brackets on the top of each one are wrong.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 09-01-2007, 01:58 PM   #6
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
I just walked out to my top that is hanging in the garage. The top mounting brackets look a lot different from what you have. They are basically flat, not angle iron shaped. Those might be from a Suburban.
No repops are available as far as i know. You might be able to find them used. Or,if you cut the angle part off, you might be able to get those to work. Drill some holes and put some threaded inserts into the hatch.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 09-02-2007, 03:03 AM   #7
71jimmy
71jimmy's Avatar
Here is a correct '69-'72 pic of an extra set I have.
'71 Jimmy, 350, SM465, NP205, 2in Tuff Country lift, 33s on rallies, TBI, softtop and hardtop
"If life was fair you'd be able to afford one of each and a garage large enough to house them all."
71jimmy is offline   Reply With Quote
Old 09-02-2007, 08:39 AM   #8
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
That's what i have on both of my single wall tops
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 09-02-2007, 02:53 PM   #9
crzngmychvy
"1972 C5"
I was wrong earlier, the last pic is the kind I have too.
2wd Blazer Page
Old 09-02-2007, 03:21 PM   #10
gringoloco
A guy with a truck
gringoloco's Avatar
Thanks guys. Just bought a set off the parts board. This place rocks!
Anyone know about the disconnect plate and the wiring harness, or will I have to find them used?
Thanks -Chris
-Chris
