09-02-2007, 09:23 PM | #1 |
Problem may be solved.....
I have been having a problem getting the roof line just right on the extended cab project that I am working on. It is close be not really what I wanted it to look like. Thanks to the part that I picked up from "Uncle" yesterday, my problem may be solved. With some work of course.
09-02-2007, 09:54 PM | #2 |
PROJECT 7DEUCE
Re: Problem may be solved.....
And somewhere theres a convertible suburban....... That should fix the roof area of the crew cab..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
09-03-2007, 07:57 PM | #3 |
Keep us update, can't wait to see how it comes out.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
09-03-2007, 09:42 PM | #4 |
I hope you use the square cornered sub front doors and rounded rear doors
09-04-2007, 05:22 PM | #5 |
09-04-2007, 05:35 PM | #6 |
Questionable
Tim's a good guy, sells at good prices. and this is a project i'm going to keep my eye on, looks pretty cool!
i like that you're going with a sub top rather than two standard cabs. i think the two-cab merge trucks look pretty crappy. this one should turn out pretty good.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
09-04-2007, 05:45 PM | #7 |
How much of the top do you plan on using? I might need what you have left.
R
09-04-2007, 08:05 PM | #8 |
I cut the sub top off even with the back door, leaving from the rear window back.
09-04-2007, 09:52 PM | #9 |
is that part straight? If so, I might need part of it to straighten out some stuff on my crewcab.
09-05-2007, 08:12 PM | #10 |
The metal on top is real good. There is some rust behind the driver side window area. I still may have to use the part that rolls down at the back to match up the back of my cab.
09-05-2007, 10:37 PM | #11 |
I need a piec about 35" wide to go in the marked area below.
09-06-2007, 08:14 PM | #12 |
09-06-2007, 08:44 PM | #13 |
nothin good ol fashioned work cant solve, cant wait to see the outcome
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
09-06-2007, 08:50 PM | #14 |
It will be easier making that one work than making one from scratch .
12-11-2007, 06:14 PM | #15 |
I finally got a little more work done on this project. It has taken a while, but the top is starting to come together.
12-12-2007, 12:47 PM | #16 |
Looking good! You need to post more pictures, . How much of the roof do you have left?
R
12-12-2007, 06:28 PM | #17 |
12-12-2007, 07:10 PM | #18 |
I need a section about 3 feet wide if you want to get rid of it.
08-16-2008, 10:27 PM | #19 |
Progress has been slow on this build but hopefully that is about to change. I just ordered a set of suburban doors from GMCPauls. When they come in I will be able to see how much more work roof has left and get the b piilars put back together. Then things should move along a little faster.
12-13-2008, 12:15 PM | #20 |
Here is a picture of the progress so far. It has been a slow go but any progress is good progress I guess.
