longer wheels stud help
i have a 9 inch ford rear end with moser axles under my 68, recently i put on a set of baer disc brakes and now i need longer wheel studs. Here is the problem, the studs i have now are 1/2" x20 1.5" inches long with a .530" knurl. i need the same but around a 1/2" longer, i cant find anything like this, is it possible to drill the knurled hole in the axle and pull a stud with a larger knurl into it?
http://store.summitracing.com/partde...5&autoview=sku these are 1/4 of an inch longer but with a knurl size of .565" . |
Re: longer wheels stud help
man this board moves fast, already on page 2
ttt.. |
i don't see why you couldn't but i would think they are out there. did you call summit? just because they are not listed in there catalog don't mean they don't have them. also check with the dirt track guys
common sense isn't so common anymore |
Mine came from Summit or Jegs, I had to ask for them.
05 2500HD 6.0 excab 69 LWB-Gone but not forgotten! 68 Dodge Charger 383/727 69 Dodge Charger-440/4spd |
