Old 09-06-2007, 03:59 AM   #1
CentralCoaster
CentralCoaster's Avatar
Where's the factory dummy/idiot oil pressure light?
My truck came bare bones from the factory with 3 guages, but the prev owner put a deluxe 7 guage suburban dash in there.
I want to have an oil pressure dummy light in addition to the electric autometers I just put in.
For now, I've got the oil pressure switch powering the "TEMP" dummy light in the stock fuel guage. Good location, just wrong text. The other light inside the fuel guage is for "BRAKE"
Where was the original dummy oil pressure light? It wouldn't hurt to use the same light for both temp and oil I guess... sort of like a "check guages" light.
Call me anal.
1969 C10 Stepside, 350ci, 700R4
CentralCoaster is offline   Reply With Quote
Old 09-06-2007, 05:41 AM   #2
Re: Where's the factory dummy/idiot oil pressure light?
With a gauge no light is required and that`s how trucks were outfitted,either or.
Old 09-06-2007, 10:56 AM   #3
CentralCoaster
I know that. I want both.
Where did GM put the oil pressure dummy light on the non-guage dash? Was it integrated with the speedo or fuel guage?
Old 09-06-2007, 04:12 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Neither, it was in the center pod with the turn signal indicators and the charge light.
Old 09-07-2007, 01:34 AM   #5
CentralCoaster
Thanks!
Old 09-07-2007, 05:41 AM   #6
That`s what I was indicating.You won`t get both in one.There won`t be a place provided on a "gauge" dash.So,put it where you want.I think it`s a good idea,too.If you don`t have a tach,it would be cool to "hybrid" the two dash types together.
Old 09-07-2007, 04:38 PM   #7
Longhorn Man
I think a buzzer is a good idea too... possibly more important than a light IMO.
Old 09-11-2007, 03:28 AM   #8
CentralCoaster
Ok, all done. I wired up a solenoid on the visor so it swings down and smacks me upside the head anytime oil pressure runs low.
Next question, if you run it low on pressure, say, zero pressure for 5 seconds on a warm motor at cruise rpm and no load, what harm would that cause?
Old 09-07-2007, 07:29 PM   #9
I think there should be a tube rigged up to squirt the last bit of oil into your eye just before the motor siezes.
Old 09-11-2007, 07:33 AM   #10
First...
Next...5 seconds?Prolly take a couple few thousand miles of the bearings.In a minute or so gauling (gouges/lost pressure) would occur,bad.When pressure is first lost there is still oil on everything.It takes a bit to dry that off.
Old 09-11-2007, 10:03 AM   #11
StingRay
StingRay's Avatar
I have done the use one light for both in a gauge dash. I used the wires from the non gauge dash harness and they clip right into the gauge harness. I then used the idiot light senders for the non gauge dash wired to the one idiot light wire. The senders just ground out to activate the light. I used a tee at the oil pressure port and used the sender hole in the other head for temp. I use it like a check engine light. If that light were to come on I'd be checking the gauges really fast.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 09-12-2007, 11:40 PM   #12
CentralCoaster
Same here.
Although the connector is the same, the pins are not. I repinned my dash connector to work with the guage dash, even though I'm using seperate wiring for all the lower guages.
I think the fuel guage, signals, and backlighting all had to move to different pin locations to work right. There's a website somewhere that shows it in detail.
Old 09-20-2007, 04:06 PM   #13
Zeus
Zeus
My 67 had idiot lights. I replaced the cluster with a gauge cluster and now everything is messed up. HELP what is the website to relocate the pins?
jesusventura@hotmail.com
Zeus is offline   Reply With Quote
Old 09-20-2007, 04:35 PM   #14
john
member #16
john's Avatar
from gmc pauls truck parts
http://www.gmcpauls.com/Tech%20Tips1.htm
john is offline   Reply With Quote
Old 09-20-2007, 05:17 PM   #15
Longhorn Man
You'll be needing a fuel guage now too, i can't remember if anything else gets fried, it's been a while since I did that.
