09-07-2007, 09:07 PM | #1 |
Lockup Torque Convertor
Is the lockup torque convertor on the TH350C electronically or hydraulically controlled? I was wondering because if it is electric I would like to hook to a switch inside the cab so I can switch it off whenever I am towing.
09-07-2007, 11:47 PM | #2 |
glamoros piece o' lowlife
Re: Lockup Torque Convertor
electric - there's a plug on the driver side of the tranny IIRC, that's what controls it
The more I drink, the more I drink, the more I drink... diesel, reg cab, long bed, 4 across the rear, single stack, wooden stakes, and lotsa lights - the Hay Express |
09-10-2007, 12:19 AM | #3 |
You r correct sir!!!!
87% of all statistics are made up on the spot. |
09-10-2007, 12:40 AM | #4 |
It followed me home?
Dont mean to hijack your thread here but would someone please explain what lock up means and what it does? use small words if you can I'm not much of a mechanic ha ha
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
09-10-2007, 09:43 AM | #5 |
On a budget like Fred Sanford
A lockup converter has a clutch inside it that locks the two halves of the converter together at cruise speeds. This lowers the rpm, gives greater fuel economy and reduces heat in the tranny.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread '98 Camaro z28: 370ci twin turbo 370ci build '01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD |
09-08-2007, 11:09 PM | #6 |
Insert Witty Text Here
Ivan's correct.
Here is a schematic that might help. http://67-72chevytrucks.com/vboard/s...d.php?t=217155 Slonaker |
