Noobie McNoobster
1971 K20 Axle Swap
I have a source for a full set of axles out of a late 80's 1 ton 4x4 fleet side (Dana 60 front and 14 bolt FF) , what would I have to do to get them to work? e.g. swap perches spring mounts, etc? Thanks.
P.S. my 68 has 71 running gear right now, and I am looking for added flexibility when it come to upgrades (brakes and gears), and I am also planning to go with a big block in the not too distant future.
The Stable: 1968 Chevy K20 w/tilt, working AM/FM, AC and 350/350/205 w/Disk Brakes ![]() 1990 Chevy V2500 Suburban 2005 Kawi KLR650 1983 Honda Goldwing GL1100 Standard (Naked) 1995 Miata M Fortes Fortuna adiuvat |
Re: 1971 K20 Axle Swap
The 14 bolt rear wont require spring perches being moved but the shock mounts will have to be moved.
The front should just be a simple bolt in with the spring plates,ubolts,etc. I dont know about driveline mods... Last edited by 1969k10stepside; 09-09-2007 at 03:38 PM. |
#3 | |
Noobie McNoobster
Wow just noticed your sig..looks like someone has been busy scarfing up all the 69-72 trucks in your area :-D
Are you planning on running some pretty big tires? 38" or taller? If not, I would say sell the 1 ton axles and just pocket some coin. SRW D60's seem to fetch more $$ with each passing day.
1969 GMC K2500 ![]() 1996 Honda Accord 2007 Kawasaki KLR 650 |
Noobie McNoobster
Actually I plan on hauling a 15,000 pound goose neck trailer with a 502 under the hood. So I need the better brakes up front and I also don't feel good about putting that kind of stress on a D44 front. I think the HO52 I have is plenty strong but the 14BFF I am looking at has a locker and brakes and gears are a lot easier to find.
#6 | |
I didn't notice you have a KLR. How is that treating ya?
#7 | |
![]() Join Date: Feb 2007
not to get off track, but what's the census on towing with a locker? i've heard alot of points for and against towing heavy loads with say a detroited rear. the 4x4 mags have written articles both ways and one even built a tow rig using a detroit not long after posting an article about not using a locked rear for heavy tow applications.
regardless, enjoy your build! -steve
Steve 1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's |
