Old 09-09-2007, 10:59 PM   #1
bucky_21_7
bucky_21_7's Avatar
Headers Will they work?
I'm putting a new v8 in my 72 chevy c10 and i was wondering if these headers will work with my 4 speed. It's a 307, saginaw 4 speed truck. I'm contiplating between these 2 sets. If anyone has these any info on how they are would be great. Thanks.
Hedman 69092 - Hedman Hedders Headers http://www.jegs.com/webapp/wcs/store...10002_36226_-1
Hooker 2452 - Hooker Headers Competition Headers http://www.jegs.com/webapp/wcs/store...10002_16922_-1
Just making sure cause i just ordered a shifter linguage and it won't bolt on to the tranny so i don't feel like making that mistake again. Thanks
bucky_21_7 is offline   Reply With Quote
Old 09-10-2007, 07:03 AM   #2
Re: Headers Will they work?
Blow into one end and if air comes out the other end,then they work.Sorry,just kiddin`round.I`ve heard the SuperComps work and the Headman Elites.I have the second,but haven`t tryed,yet.Everytime this questionarrises it never seems to bring a definative answer.I figure worst case,I ll move an arm on the bellcrank.Been there/done that.
Old 09-10-2007, 08:51 AM   #3
Gray Ghost
Gray Ghost's Avatar
Call the vendor for confirmation ,but they should work since they don't list a code telling you it may be a problem. They did mention clutch linkage in the Hedman notes.
I prefer Hedmans....they fit better and wear more gracefully.
Kelly
'05 GMC Sierra SLE Z71
Bone stock except for new bed rail caps.
Gray Ghost is offline   Reply With Quote
Old 09-10-2007, 10:16 AM   #4
crazy longhorn
Fabricate till you "puke"
Assuming that your truck was a V8 from the factory(eng on correct V8 stands), either set of headers will work......I prefer the Hookers for fit & ground clearance on a lowered truck tho.... The Hookers will also fit the sb in I6 spot, but in the Hedman line, you need the 69090 IF you are in I6 spot. best of luck L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 09-10-2007, 11:24 AM   #5
KFreddy
Active Member
KFreddy's Avatar
Take a look at http://www.sandersonheaders.com/ they have their price but I believe that no other product even comes close in quality, fitment and durability...
"The Great State of Florida"
KFreddy is offline   Reply With Quote
Old 09-10-2007, 02:15 PM   #6
JameslovesJammie
God Bless Mr. T
JameslovesJammie's Avatar
Except Doug's Headers or Thorleys.
Like a midget at a urinal...sometimes you must stay on your toes.
JameslovesJammie is offline   Reply With Quote
Old 09-10-2007, 10:09 PM   #7
Do cast Sandersons compare in flow?
Old 09-10-2007, 10:55 PM   #8
KFreddy
Active Member
KFreddy's Avatar
K,
I kinda fell in love with the Sanderson QP2100, the cast units. I thought they had a great old school, pseudo sleeper, stock look to them. I really would have liked a black jet-hot coat on them over the silver that I had done. The intake side is 1-7/8' and the exhaust collector side is 3", exhaust flange if i remember is about 1" thick, really beefy stuff. In theory they flow, certainly not holding back my 454, but I would imagine that a block hugger or full length design would flow better. I'm very happy with what I have and get comments of approval all the time, they really are sweet and different pieces.
