09-10-2007, 02:45 AM | #1 |
Standard bed to stepside conversion
I have a 79 half-ton pickup with the standard bed. It is rusting. Or should I say it is rust. I've been thinking about replacing it and have always prefered the look of the stepside. Can I simply find a stepside bed off of another comprable truck and swap it with mine? Or would there be major modifications to the frame in order to get it to fit? I don't know if it's just an optical illusion or not, but the stepside seems shorter.
Thanks, Guardianfyre
'79 Chevy 1/2 ton currently: trying to trace an oil leak |
09-10-2007, 03:20 AM | #2 |
Wishin' I had more money!
Re: Standard bed to stepside conversion
I always thought the bed mounts were different on a stepper
09-10-2007, 07:50 AM | #3 |
The step beds are the same length on the inside and use the same mounting points. I think the step beds use shims or spacers in a few places to get the bed level on the frame. Make sure you get the all the fuel filler hardware and the rear bumper and brackets, those differ between the step beds and the fleet beds. My experience has been that the step bed unique stuff can be tough to find.
The step beds rust at the fender attaching flanges and at the step attachments. You need to check this out from inside the fender opening. The step tailgates and sport bumpers are the same from 67-87. The beds are similar between 67-72 and 78-87 but not directly interchangeable. |
09-10-2007, 02:40 PM | #4 |
I thought stepside tailgates were all the same from the mid 50's and up ?
09-10-2007, 08:51 PM | #5 |
09-11-2007, 10:21 AM | #6 |
www.73-87chevytrucks.com
Find the donor and bolt it on. Simple as that....
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
09-13-2007, 10:13 AM | #7 |
Truck CRAZY!
i did this a few months ago and its just as simple as bolting on the bed and making ur gas filler hose fit!
84 Chevrolet stepside, 350 with .60 over pistons, aluminum zr1 heads, doug herbert .500 lift cam, 1.6 roller rockers, elderbrock intake with a 600 holley carb, mated to a 700r4, 208t-case and 4-11 gears,33 goodyear wrangler mtrs |
09-13-2007, 10:18 AM | #8 |
What Hump?
My neighbor on his 82 did the opposite, step to fleet, only had to deal with what 84 said. Take pics of the conversion and save them for someone else who will want to do the same thing and then there be a refrence for it.
Lil red 86 c-10 99 Sub 78 Camper Special w/ 454 |
