09-10-2007, 09:46 PM | #1 |
Pics 4 Hartrod.
Take a look. Took the pic of the d/s frame end to show what it should look like.
09-10-2007, 10:29 PM | #2 |
Re: Pics 4 Hartrod.
It doesn't look that bad, but I would like to see so more pictures. Those are so close and the lighting make them hard to see. I'm talking about the cracked bracket not the bent frame. Frame is of now worry. Can you take the hitch off allso? thanks
Rob
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 09-10-2007 at 10:30 PM. |
09-10-2007, 10:39 PM | #3 |
Re: Pics 4 Hartrod.
I'll get more pics tomorrow.
09-12-2007, 08:38 AM | #4 |
Re: Pics 4 Hartrod.
More pics and I tried to show where the support area is.Disregard the first pic.
09-19-2007, 10:24 PM | #5 |
Re: Pics 4 Hartrod.
If you'll replace the broken area and take the hitch off, I'll call it good.
R
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
09-20-2007, 04:05 PM | #6 |
Re: Pics 4 Hartrod.
Hitch is off. Explain what you mean by replace.
09-20-2007, 05:22 PM | #7 |
Re: Pics 4 Hartrod.
You mentioned in a PM that a bracket was broken and needed replaced:
"The other piece was on the pahard bar mount. It has a crack form the bushing being worn out on that end. It loosened the rivets that hold it to the frame and put the small crack that you see. I think you can just bolt another bracket on instead of having the rivets. I have several brackets. " R
09-20-2007, 06:18 PM | #8 |
Old Skool Club
Re: Pics 4 Hartrod.
What is a "d/s frame"? I am in the dark.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
09-20-2007, 06:27 PM | #9 |
Junior Member
Re: Pics 4 Hartrod.
(d/s) driver's side
'63 C10 lwb flatbed '66 C10 lwb stepside '68 C10 lwb stepside (parts) '68 C10 lwb fleetside (17 yr old son's ongoing project) '03 HUMMER H2 (wife's) '06 3500 flatbed liftgate (My work truck) |
09-20-2007, 08:53 PM | #10 |
Re: Pics 4 Hartrod.
The bracket is not the part that's cracked. It's the reinforcing plate that runs along the frame. I told you in the pm that I would cut that part out of another frame for you.
09-20-2007, 09:29 PM | #11 | |
Re: Pics 4 Hartrod.
I really don't want to disassemble the rear of the frame. Do you have another frame?
09-20-2007, 09:51 PM | #12 |
Re: Pics 4 Hartrod.
That's the only one I have.
10-05-2007, 04:52 PM | #13 |
Re: Pics 4 Hartrod.
Tim,
I got home and started looking at my frame and maybe the pictue you took just confused me. On my frame it looks like there is only a short bracket that has to be replaced requiring only 4 or 5 rivets to be removed. How many rivets would have to be removed to replace the bracket on your frame? I apologize for the hassle, but this is hard to do long distance. Thanks Rob
10-05-2007, 04:53 PM | #14 |
Re: Pics 4 Hartrod.
Is your frame a 3/4 ton? Maybe that's the difference. Your frame looks like it is beefed up more in the back than mine.
R
10-05-2007, 09:26 PM | #15 |
Re: Pics 4 Hartrod.
It's a 3/4 frame and that sounds about right on the amount of rivets. The other piece can be welded without removing.
