65 - Chevy C10
Steering Wheel Switch
Does anyone know of any write ups on how to remove steering wheel from our trucks and put on another?
Re: Steering Wheel Switch
It's a simple job. Remove the horn button. Then remove the big nut holding the wheel on the shaft. Get a steering wheel puller and screw in 2 5/16 bolts into the wheel itself. Now start screwing in the center of the puller and the wheel will pop off once the seat is broken. To install just put the wheel on and tighten the nut.
63 short fleet Patina build http://67-72chevytrucks.com/vboard/s...d.php?t=287751 Man I want another one. |
yes, i do
make sure your tires are as straight as possible or the steering wheel won't be straight when you have your tires straight. speaking of which, i need to straighten my steering wheel
