09-16-2007, 11:17 PM | #1 |
PorterBuilt Man Crush
PB DropMember install
Went pretty smooth putting it in, only took a couple of hours. Granted I am not done with the notch or rack, but I like the way it looks. I mocked it up at ride height with a 1" rake in the back. It was funny without the bags in, I dropped the jack and the frame got stuck on some small pieces of stuff I had laying around. Damn this thing will get low!!. I love it. Thanks Nate for you help, and your kick ass product.
The 72 will live again Last edited by jasonb72; 09-17-2007 at 03:15 PM. Reason: updated title |
09-16-2007, 11:19 PM | #2 |
Re: And another PB install in the books
More pics
The 72 will live again |
09-17-2007, 12:02 AM | #3 |
chevy only
lookin good ,and it well drive even better
09-17-2007, 12:06 AM | #4 |
I can't wait to test that theory. I am trying to catch you Dino, so..... that means I just need about 15 more dropmembers to go right!!
09-17-2007, 10:10 AM | #5 |
Looks awesome. Did you not get the dropmember to lay out? I see you've got some coil springs in the background, bumpstops on the a-arms, and the bell-housing crossmember still in which will bottom out way before the dropmember.
09-17-2007, 10:29 AM | #6 |
It would have bottomed out without the bags in. I do not have my cups for the bags yet, and the rear is still on jack stands so I did not want it to fall. I still need to cut the other BH member out, but at the ride height I have it set at that member is just 3" off the ground. When I let the jack go the upper bag plate smacked the hell out of the bumpstop, compressed it about 2" or so. I will probably need to cut it down or get a thinner one.
09-17-2007, 11:02 AM | #7 |
Pics with the blocks removed.
09-18-2007, 02:26 AM | #8 |
New Member
Nice job Jason. welcome to the drop member club . What are you doing for the rear?
Anthony 63 chevy stepside SWB 57 chevy 2dr hrdtop belair |
09-18-2007, 11:29 AM | #9 |
Still debating on the rear......
09-18-2007, 06:28 PM | #10 |
Hay other than the bump stop hitting would the c p p arms work with the dropmember
nickle and dime |
09-18-2007, 06:59 PM | #11 |
Yes, with a pair of cups for the bags. I am waiting for my cups, and I will then see how much I will need to hack off of my bump stop. I am hoping after the 2.5" cup that I can get away with whacking only an 1" off the BS.
09-18-2007, 07:00 PM | #12 |
And really it's not the DropMember with the problem, it's the CPP arms that put a big azz bump stop where there was not one before. As you can see there are plenty of people that use stock arms with no issue.[
QUOTE=royo;2364244]Hay other than the bump stop hitting would the c p p arms work with the dropmember[/QUOTE]
12-18-2007, 07:56 PM | #13 |
hey man thats for the help earlier but how much did all that cost? what came with the dropmember? i kinda needed a price range to give my customer, i saw an ad for a middle cross member i guess behind the tranny or something....
12-18-2007, 08:11 PM | #14 |
I am not sure what the cost is now for evertything. You might check out the site www.dropmember.com you can get the list of what you get with the kit. Or you can just pm porterbuilt, and he will give you a break down. Like I said, it is definately worth it if you have the budget vs the billed hours it would take to do a Z, or section the crossmember, and all the other fab work involved with those options that are solved with this bolt in. Give Nathan a buzz, and he can give you the skinny.
J
12-19-2007, 06:38 AM | #15 |
Formerly ADHDCARGUY
Beautiful!
Jay 67CHEVY SWB,355, built 700r, 5/7,9",posi 3.50,REAR BAGS,HOOSIERS, A/C. 54CHEVY - BURB, beginning construction(well, i gotta take it apart first!) 36FORD PU - WAITING 38CHEVY - 2DR SD,CHASSIS FINISHED 46CHEVY - BURB - waiting |
12-21-2007, 06:38 PM | #16 |
chevy only
looks good bro..welcome to the club (dropmember only)
12-21-2007, 08:29 PM | #17 |
I'm a sargent in the club (or was that the SOB of the club..... ). Nate should supply a Dickies style 'Dropmember Club' jacket for those w/more than one .
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 12-21-2007 at 08:32 PM. |
12-21-2007, 08:50 PM | #18 | |
3DrDwn--the 'burb not the band
Josh
Slo and Lo that is the tempo. '72 burb build page here: http://67-72chevytrucks.com/vboard/s...d.php?t=259256 '89 GMC Dually crew build page coming soon. 88 4x4 crew DD duallys past/present pics here: http://67-72chevytrucks.com/vboard/s...46#post4001246 89 1 ton Dually rear flip kit install here: http://67-72chevytrucks.com/vboard/s...d.php?t=354327 |
12-22-2007, 05:11 AM | #19 |
Jim '71 Blazer-Porterbuilt Dropmember C4/LS1/6L80E '57 VW beetle - Oct. 2006 Hot VW's pg. 87 - 350hp intercooled, turbocharged, EFI 2.3liter and 5spd in the works '87 BMW 325i - daily driver |
12-22-2007, 07:25 PM | #20 |
Village Idiot....
Well I guess I should have Four Stars on my shoulder since I have a dropmember and a Full Custom Frame!
http://www.hubgarage.com/mygarage/n2billet -67 SWB Custom Porterbuilt Front and rear 20/22's Hazel Sold -71 StepSide Porterbuilt Stage 2 with 20/22's Stella Mae Sold |
12-23-2007, 09:03 AM | #21 |
Nate,
When are you really gonna start making Jackets cause I want one! Later Tony from Norcal |
12-26-2007, 07:56 PM | #22 |
chevy only
man, my jacket should at least have hood with fur...
CHEVY ONLY... Nothin Else ! |
12-24-2007, 12:14 PM | #23 |
I say we need a rendering of Nate laying down some wicked welds on the back.
12-24-2007, 02:19 PM | #24 |
12-24-2007, 07:02 PM | #25 |
Actually a little more serious, how about DROPMEMBER spelled out in Wicked Weld Font. I bet we could get the art work done
