3 speed to 4 speed on a 4wd
I am working on my k20 with three on the tree. I also have a 4 speed transmission from a c20. What all is needed to swap the 4 speed into the truck to get rid of the column shift?
Look like it will not mate right up to the x-fer case shift housing. ![]()
1970 K20, 350--- SOLD 05 silverado extended cab short box- duramax Jeep wrangler unlimited |
Re: 3 speed to 4 speed on a 4wd
Different adaptor/pedestal.
Ya, I was afraid of that. Just another part to hunt down
huh ???
The C/20 trans will be a 2 wheel drive trans. You might have a length issue with the 4spd's output shaft...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
I think the 2wd tranny has more output splines as well.
68 Chevrolet k20 Longbed 350 SM465/205, Dana 44, 14bolt, Power steering, Power Disk Brakes, 35" BFGs. 84 Chevrolet Suburban K20 6.2 Banks turbo TH400/NP208 Now with G80 68 GMC C20 Parts? Truck And a few cars ![]() |
if you have a long wheel base switch to a divorced transfer case it makes life easier and will let you use what ever trans you want to use.
Earl 68 2500 4x4 GMC Burb |
Yeah,that^^^.Gives you a better front shaft angle,as well.
options, options. I could also tear apart the trany and put in the right output shaft.
