bench interchange help
will a 67-72 bench seat bolt in to my 64?or is there some mods that need to be done?what years fit and any mods required?i want to get the buckets out and go with a bench.thanks
![]() Join Date: Oct 2006
Re: bench interchange help
you might have to drill a few holes that should be it.
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
It Is What It Is
67-72 Bench will bolt in, but you need to shim the front. On 60-66 trucks the floor pan is flat where the seat bolts. So the angle of the seat is in the mounts. On a 67-72 the mounts are shorter on the front because the floor has a ridge that the seat bolts too. unfortunately the mounts do not interchange between the two seats.
cool thanks.that helps since ive found some 67-72 seats on craigslist.
