Old 09-20-2007, 04:58 PM   #1
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Question C-Notch (Pros and Cons)
Ok let me have it, I have the kit, but on the fence about installing it.
Right now aired out sitting on the rear snubbers I have 1/2" between
the frame rails & the rear axle. Obviously this would let me get down
a few more inches before the punk'n hits the bed floor. I'm only using
17's at the moment, but long term want to go either 18/20 or 20/22.
I just finally got the 15's off week before last so I am sorta stylin
My question is if I am going bigger down the road, hence more tuck,
what do I gain from installing the C-notch other than it aired out flat
on the ground look? Keep in mind I'm aproaching 40ish so I want it to
have the ability to drive aired out incase of a highway emergency
Here is the 15" pic, center of fenders was 25" F and 27.5" R, now it
is 25" F and 25.5" R with the 17's but I can't get new pic's just yet.
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 09-20-2007, 05:15 PM   #2
Frizzle Fry
Frizzle Fry's Avatar
Re: C-Notch (Pros and Cons)
You get the ability to RIDE at that height instead of just being parked. You will still be able to set up bumpstops that allow you to remain mobile when aired out. With 20s/22s you will need to start looking at making more room ie. inner fender/tub mods.
Frizzle Fry is offline   Reply With Quote
Old 09-20-2007, 05:29 PM   #3
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
But not with 18/20's combo right? That may settle that idea
PS - I was hoping you would chime in since I consider you a Pro
Old 09-21-2007, 12:03 AM   #4
Frizzle Fry
Depends on the wheel/tire combo, but from what I've seen (and I'm no pro) you should be able to select a combo with rear 20's that will bottom out the c-notch at the same point that the tire starts to rub. Set your bumpstops a little before that point and your golden.
See Ten has a good point though. Might as well accept that you need a little bubble in the floor if you're going to notch it.
Old 09-20-2007, 08:27 PM   #5
gringoloco
A guy with a truck
gringoloco's Avatar
Lowers your ride height and will allow a larger diameter wheel/tire without raising your ride height. Just do it- it's not like you're hacking the thing up- it's a bolt-in kit from CPP I assume?
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 09-20-2007, 08:37 PM   #6
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
I believe so, it was another toy included in my package
Old 09-20-2007, 10:14 PM   #7
see ten
WTB this ad
see ten's Avatar
Craig are you going to clearance the bed floor or let it self clearance? Seriously, my truck is in the 2.5"-2.75" range measureing from the axle tube to the frame. Meanwhile the ol chunk a dunk on the axle only has roughly an inch more than the previous measurements. So even if I go with a notch I'm only going to gain about another half an inch of travel (assuming I run some kind of bumpstop to slow down the motion before things get ugly with the floor. Of course I could always pull the old 4x4 trick and see how much I could shave off the diff. In games like these I guess every little bit counts!
see ten is offline   Reply With Quote
Old 09-20-2007, 10:52 PM   #8
1969k10stepside
If it was me I'd settle for it's current height as opposed to cutting and chopping a original 2wd...that's my 2 cents...
1969k10stepside is offline   Reply With Quote
Old 09-21-2007, 02:30 PM   #9
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Hmmmm, ok that's more to ponder over, let me think on this
