Old 09-21-2007, 08:58 AM   #1
KTLX
Question Dead in the Driveway - Electrical help Please
When I turn the key to start the engine nothing happens, the engine won't turn over. I tried cleaning the battery connections, I changed the ignition switch, and it still won't turn over, the starter solenoid doesn't even click. The lights, radio, etc. all work and the battery has 12 volts with the headlights on. If you can give me any help with this problem, it would be much appreciated
Kenny
KTLX is offline   Reply With Quote
Old 09-21-2007, 09:24 AM   #2
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Re: Dead in the Driveway - Electrical help Please
Check the purple wire on the back of the starter,for loose and for 12v.
If you are getting 12v, then the solenoid is bad. If no 12v then check safety switch on column under dash.
sneakysnake is offline   Reply With Quote
Old 09-21-2007, 09:33 AM   #3
dan42
dan42's Avatar
Is it an automatic? (Nuetral safety switch...) if it is , push shifter lever up a little harder and see if that does it. The connection (I think) gets bad. It does on my '70 with a TH350.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 09-21-2007, 10:36 AM   #4
KTLX
All, thanks for the great replies, 4 speed, to check the 12v to the solenoid, is it as simple as disconnecting the purple wire and putting a electrical tester to the solenoid and to the purple wire. Assume if the test light goes on the solenoid is dead
Kenny
Old 09-21-2007, 11:07 AM   #5
ChevyC102007
ChevyC102007's Avatar
You could always try the "screwdriver cross method" with someone holding in the clutch so the truck wont roll ya over, thats another way to check and see if the solenoid is stuck, or try rapping on the starter with a hammer while someone trys to get the truck to turn over. Just my .02 cents
"When you were born, you cried and the world rejoiced.
Live your life so that when you die, the world cries and you rejoice."
[Cherokee saying]
2001 Dodge Ram Sport 1500 4x4. (old ride)
1987 GMC V1500 Sierra Classic ("new" ride)
ChevyC102007 is offline   Reply With Quote
Old 09-21-2007, 11:52 AM   #6
sneakysnake
Go from the purple wire with tester to ground ( any clean metal surface)
Old 09-21-2007, 11:09 AM   #7
wibilly
wibilly's Avatar
with the key on red on purple wier and black to a good ground
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 09-21-2007, 03:28 PM   #8
sb69chevy
sb69chevy's Avatar
You may have checked this, but...Is the back nut tight on solenoid's battery terminal connection? Had this happen to me. Positive was "tight", but no juice was getting in there since the back nut was too far away from the solenoid. Just a thought.
1969 C/10 swb, 350, powerglide (daily driver)
2005 CRV (wife's ride)
sb69chevy is offline   Reply With Quote
