And you call that a what?
Hello guys, new guy here. Been reading your post for a couple months or so now. Have purchased three trucks recently, 67 and 68 short step chevys and 70 long fleet 3/4 ton chevy, to start my collection. Planning on combining them to make one or maybe two good trucks. Starting work on 67 frame now. Question is this: Converting to five lug. Taking advice from other post, I have the front end parts from a 73 and plan to just swap everything out. But what abt rear? Whats the easiest way to convert this? Been on the hunt for five lug rear from later year, but can't seem to locate. Have seen a few here and there, but for leaf susp. Need coil. Is it possible to just swap axles? Or can I even get five lug axles for a 67 rear? Any help here guys?
Fabricate till you "puke"
Welcome from Ill! you can order a set of axles from http://www.moserengineering.com/ for about $260. Due to the width differences, the 71-72 axles cant be used in the 67 rear diff. good luck ........Crazy AL
'Heavy Metal' Redefined.
For suspension, disk brake conversion, and rear end kits you could also check out http://www.brotherstrucks.com/.
Welcome to the Board! Mike
1967 C10 LWB stepside, 250 engine, GM HEI, aftermarket A/C., Clifford Performance intake, Stovebolt split headers, Carter AFB 500, X-pipe & Dynomax Super Turbos, 1 piece custom driveshaft, cyprus bed wood & stainless bed strips. Starkville, Mississippi | My Truck Page |
More hobbies than money!
Welcome to the board.
If your good with a torch I understand you can convert from leaf to spring setup. I'm not.
'70 cst10/swb 350, 3 on the tree, factory buckets. '70 GMC lwb 350/350 ps,pb '72 c-10 lwb 350/350 a/c, ps, pb '72 Blazer project |
to add to my question above: am I correct in thinking that 71-72 rears are the only ones with coils and 5 lug? 73 and up are all leafs right?
Yes, 71 and 72 only ones available with coil and 5 lug. 73+ had leafs
'72 Cheyenne. AC, PS, PB, Rear slider window, tilt. Light yellow (grapefruit yellow according to new sales literature from '72) '56 Chevy short step V-8 (My dad bought it new!!) '70 Olds 442 convertible '70 Olds Rallye 350 |
CCRider
There is an adapter kit avalible to make 73 up rear ends work with coils. You can get it from Chevy Duty, I'm sure other places carry it too.
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS |
OK, anybody ever done one of these convertions like Tom is talking abt? How hard can it be? Mike
Welcome aboard.
