Old 09-22-2007, 07:25 AM   #1
BurnerBrown
BurnerBrown's Avatar
Manifold question
Are ramshorn manifold studs theaded into the manifold? Just got LMC dual exhaust and I can see the manifold studs are shot and will need to be replaced. Whats the best way to go about this? should I pull the manifolds off?
BurnerBrown is offline   Reply With Quote
Old 09-22-2007, 08:12 AM   #2
jaros44sr
jaros44sr's Avatar
Re: Manifold question
Yes they are threaded into the manifold and second only to bumper bolts as in pita to remove. I've used a stud puller,with heat, to get them out before. I've also broken them clean off this way before.. If you take the manifold off the engine and clamp in vice you risk breaking the manifold. Good luck
I'm headed over your way this morning, going to Mienke to see if they can bend up my 2 1/2" exhaust. I have a sample 2" I'm taking with me, hope they can work off this
My opinion, new manifolds for 100.00 was the best money I've spent on the truck so far. I've may have used ones over here if my sons didn't find them first.... J.
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 09-22-2007, 08:17 AM   #3
72armyswbtruck
72armyswbtruck's Avatar
Here is a really cool trick for manifold threads:
Get a long candle and light it, let the wax drip into the threads, the was will penetrate the rust and makes it easier to remove the threads.
I would have to agree with J. new manifolds for around $100 are the best and easiest bet.
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 09-22-2007, 08:22 AM   #4
jaros44sr
jaros44sr's Avatar
That's a new one on me, nver to old to learn. So, this method is for the nuts at the flange?
SAFETY FIRST
AS usual, off topic
Jim
Old 09-22-2007, 08:55 AM   #5
cdowns
cdowns's Avatar
i've always just heated the manifolds with a torch to cherry red and unscrewed them
Old 09-22-2007, 09:14 AM   #6
mrein3
mrein3's Avatar
Me too. Only I have it done this for 10 years or so. Earlier this summer I was at a bud's place. He has torches - I don't. I brought one truck and one Chevelle manifold to attempt to pull studs.
The first one I tried, I got the manifold red hot and backed the stud right out.
YES! I still got it.
Then I proceeded to twist off the next 5 flush with the manifold.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 09-22-2007, 09:37 AM   #7
68gmsee
Active Member
68gmsee's Avatar
Best idea is new ones. But, I'm of the old school. I will give it a good shade tree shot, then go from there.
I took the manifold off and soak the bolts, heated with propane torch (I don't have oxy torch), soaked again, and then wiggled back and forth with a pair of vise grips.
If you're lucky they will come out this way, if not, they will break. I had luck with one side but broke the studs on the other one and bought a new one.
The old one is still in my garage with ruined threads after drilling and tapping the sheared bolts.
68gmsee is offline   Reply With Quote
Old 09-22-2007, 08:57 AM   #8
faribran
sdowns has the right idea---------it works
faribran is offline   Reply With Quote
Old 09-22-2007, 10:44 PM   #9
BCOWANWHEELS
i agree with cdowns totally...........
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 09-22-2007, 07:49 PM   #10
BurnerBrown
Jaros, Thanks for the offer to come up, which Meineke do you go to?
Think I'll pull the manifolds, hit em with the torch and try to work the studs slowly back and forth and see what happens. Worth a try. Thanks for the response, now I know this is as much a PITA as I has suspected. I will drop a line once I have an outcome.
Old 09-22-2007, 08:52 PM   #11
jaros44sr
jaros44sr's Avatar
Went to the one by NAPA, said my pipes will be bent and can pic up Mon. Hey, if you need my stud puller, don't know why they call it a puller since it just grabs it, give me a shout J.
SAFETY FIRST
AS usual, off topic
Jim
