Old 09-23-2007, 05:03 PM   #1
68 Stepside
huh?
68 Stepside's Avatar
What did you get done this weekend?
I didn't do a ton this weekend. I managed to get my heater box installed, haven't had one in about 6 years. As you can see from the picture, I still need to tie up all the loose ends with the wiring, and need to run hoses to the core. It's not much to look at, but here's a pic anyway.
What did you get done?
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 09-23-2007, 05:13 PM   #2
tclaremont
Re: What did you get done this weekend?
Removed and replaced the front seat and door panels
Pulled the bed
Wire brushed the rear frame
Painted the rear frame
touched up some spots with paint
Kicked the tool box while carrying the bed, creating a gash in my leg
removed and painted the AC ball mounts
Other than that... not much.
tclaremont is offline   Reply With Quote
Old 09-23-2007, 05:35 PM   #3
Friday I did yard work hoping to beat our backlash from almost storm #10.
Yesterday I installed my Grand Cherokee Electric Fan and modified shroud. I also spent a lot of time yesterday and today working on body panel adjustments, mostly doors. It's so much fun for alignment when you have a mutt.
http://67-72chevytrucks.com/vboard/s...19#post2371419
Old 09-23-2007, 06:16 PM   #4
68 Stepside
huh?
I need to watch that thread more closely Bill. It looks like you're going through some of the stuff I will eventually be going through.
I know what you mean about mutt parts, I've been through that on a friends Firebird.
I have a set of doors off my old 67 panel that I'll be modifying to fit the 68, but the funniest thing right now is that the passenger door on the 68 right now fits great, and the drivers door doesn't. The passenger side door is not original to the truck, the drivers door is
RIP El Jay
Old 09-23-2007, 06:22 PM   #5
TJ, today I wished I had kept my original doors. I got these a while back because they had were already repaired. It looks like they were not done real straight either. Oh well live and learn.
Old 09-23-2007, 07:36 PM   #6
67_C-30
I have a radical idea!
67_C-30's Avatar
I finally got all the brackets welded on the backside and got the dually flares mounted on 67 C-30. I had to do a little grinding here and there to get the fit perfect, but now there flush all the way around. Now, I've got fab up some braces for the bedside and the falre, and then take them back off and get them stripped down, sandblasted and POR-15'ed on the backside. I've also got to decide whether to use seam sealer or fender welting between the flare and bedside. I've also got to weld paches in and remove the side markers since this a '67!
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 09-23-2007, 07:43 PM   #7
67_C-30
67_C-30's Avatar
Here's a few shot of the whole truck. It really won't look right until I get the outside wheel put back on, but I took it off to have room to work.
My trucks
Old 09-23-2007, 08:08 PM   #8
Select
Friday's Toy
Select's Avatar
I finially got around to installing my Custon Audiosound stuff. From LMC I ordered the radio with CD changer controls and a 10 disk changer and the kick panel speaker set. Everything works and sounds great! The other pics are of my buddy bucket console. I installed a dual 12V port setup in it. I know it's a sin to cut into a set of buddies, but myself, I'm not a purist. I do what works for me. I have plans for the factory cigar lighter as a secutiry option.....Mikey
68 C10, SWB Fleetside with a 454, Turbo 400 and 4.11 posi....Exxon/Mobil loves me.
2009 Jeep Rubicon
2011 Powerstroke FX4 (totaled)
71 C10, SWB Fleet with factory tilt
72 LWB C10, 350 700R4 with factory tilt
Select is offline   Reply With Quote
Old 09-23-2007, 08:11 PM   #9
Select
Friday's Toy
Select's Avatar
Sorry here are the pics
2009 Jeep Rubicon
Old 09-23-2007, 07:08 PM   #10
Pont406
I installed radiator, ran battery cables and welded header collectors. I am waiting on markVIII fan, lokar linkage and I am done.
Pont406 is offline   Reply With Quote
Old 09-23-2007, 07:17 PM   #11
69GMCor70Chevy
69GMCor70Chevy's Avatar
Truck wise I just replaced my drivers side door pins and bushings. But after I took the door off 4 or 5 times to get the gaps right it took a awhile.
68 Camaro - 327 Original Red on Red Car
69 GMC LWB - Built 350 a Blast To Drive
69 GMC LWB - "Green Machine" One Family Truck
70 Mercury Marauder - Future Project
69GMCor70Chevy is offline   Reply With Quote
Old 09-23-2007, 08:05 PM   #12
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Scraped and wirebrushed front suspension parts,worked on the garage a bit,cleaned a spare bedroom and worked on finishing the home office I have been redecorating.Also,carried the dogs to the groomer and made a trip to NT to buy some more wire brushes.Pulled the inner fenders and cleaned the deck.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 09-23-2007, 08:54 PM   #13
Thealien
Thealien's Avatar
Patched a hole in the floor
Replaced a few body mounts
Painted the frame where the gas tank is going with POR15
Also sandblasted and painted all the gas tank vent lines.
Painted myself a little also. all in all a very productive few days.
Old 09-23-2007, 09:06 PM   #14
mrein3
mrein3's Avatar
Saturday I had to stick around while I got a new furnace and A/C system installed. Too windy to fish today, not enough weekend to do any big projects so I backed the 72 out and washed it. Then I washed the truck. Then I realized I've never had them all clean at once so I backed the convertible out for a picture or two.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 09-23-2007, 09:04 PM   #15
bad6772
Official Site Guitar Shredder
bad6772's Avatar
not to much truck stuff, but did the the 2nd garage cleaned, lots of yard work, gutters cleaned again, got the 49 charged up and took her for a quick spin and today is my anneversery ( 7 ) years, with the wife wooohooo... next weekend is all truck stuff
bad6772 is offline   Reply With Quote
Old 09-24-2007, 09:47 AM   #16
EAST SIDE LOW LIFE
EAST SIDE LOW LIFE's Avatar
Here is wishing you and the little lady the best.
esll.
john.
Tomorrow is for doing today's stuff.
This truck has just the right amount of energy for me!
Author: Warren Lake .... (member)
EAST SIDE LOW LIFE is offline   Reply With Quote
Old 09-23-2007, 09:20 PM   #17
tcb-1
Nothing to see here.....
tcb-1's Avatar
removed the hideous stepside bumper. since I was under there, I cleaned the rear main harness up a bit and soldered some wires back. looked over at the right rear wheel and I was leaking brake fluid. uh oh, bad brake cylinder. changed that (plan on totally rebuilding the brakes this winter so this was a bandaid).
fished out the passenger side rear view mirror bracket and while I there cleaned the door thoroughly.
cleaned up the wiring under the dash.
BUT the best part was that I was able to find something that was able to cut through 38 years of oxidation to a very nice code 504 medium green metallic. then a light buffing and viola! beautiful factory paint on my no rust Wyoming stepside.....
and my wife and I got to spend a lot of time with our 6 month old son. That's always the best time spent!!!!
tcb-1 is offline   Reply With Quote
Old 09-23-2007, 09:34 PM   #18
ctouchet
ctouchet's Avatar
I started putting my new headers (Heddman Elite), got one side done im gonna try and finish after work Monday so i can get it to the muffler shop to finish the exhaust.
2012 F150 SuperCrew
2011 GMC 1500 (COMPANY TRUCK)
1982 Chevy Blazer 2WD (Work in Progress)
ctouchet is offline   Reply With Quote
Old 09-23-2007, 10:46 PM   #19
72BlckButy
Tot Roddin'
72BlckButy's Avatar
The wife and I celebrated our 1st anniversary.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 09-23-2007, 10:54 PM   #20
dan42
dan42's Avatar
Congratulations! I got the motor I'm gonna put in my truck home. A 350 out of a '79 Blazer. I have to figure out what I can take off for pollution control stuff.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 09-23-2007, 11:07 PM   #21
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Well...I have been working on phase I of my build for the last 5 or more weekends (I know, I'm slow) at my b-i-l's shop. I've gotten the bodywork off the '72 C10 chassis and have started removing body parts from the '68 GMC and moving them over to the '72 chassis. Phase II will marry the '68 body (after going back over it) and chassis back together after I've completely built the '68 chassis from the ground up with mostly modern parts.
I've got it ready to move the cab next weekend, and start attaching the steering, brakes, fuel system, etc... and hopefully after getting around the linkage and wiring conversions....fire it up.
Based on the underside of the truck ('68) I expected the cab floor to look good...but was still pleased (read: pleasantly surprised) to find the floor is as nice as it is.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 09-23-2007, 11:08 PM   #22
lbpd719
Zappaphile!
lbpd719's Avatar
I started work on my manifold removal. been through a half a can of PB Blaster. Some are coming along nice.. Others...
I thinking I will have to have off the air injection stuff for enough clearence to get to the other bolts. that crap is nailed in as though as the other stuff. I have a buddy that will be welding up the holes in my doors this weekend.
was thinking about just keeeping stock style horns, but a little taste headers might be in option.. actively seeking opininons there..
1969 C20 LWB Camper Special - The Beater..
1998 Cheyenne V6 - 4/6 Drop - For The Son
lbpd719 is offline   Reply With Quote
Old 09-23-2007, 11:14 PM   #23
BurnoutNova
BurnoutNova's Avatar
i hung drywall in my basement all day... not near as much fun as i could of had in the garage
BurnoutNova is offline   Reply With Quote
Old 09-23-2007, 11:24 PM   #24
BHRS
BHRS's Avatar
My daughter and I took the '72 for breakfast Saturday morning, I got a haircut, then yard work.
Today I flew out of DFW to Kansas City for work. My highlight was finding out that my rental car is a new Mustang...it is alot nicer than the Nissan's I usually get stuck with. So much for working on the truck this weekend...
Glad to see what y'all have done...good work!!!
1972 Cheyenne C10
Unrestored Original-3 Owner-RUST FREE Texas Truck
Big Block-TH400-PS-PB-AC-AM/FM Radio
BHRS is offline   Reply With Quote
Old 09-23-2007, 11:50 PM   #25
sick69
sick69's Avatar
I got alot of nothing done,,,,truck or other wise.
I did throw my engine and tranny back in, just to get it off the patio. Other than that I didn't do anything all weekend,,,,,was kinda nice actually.
Frank
70 chevy lwb c10
454/th400 and a 9" rearend
suicide doors, marker light fuel fill, 4" cowl , mini tub
sick69 is offline   Reply With Quote
