Old 09-24-2007, 04:25 PM   #1
dan468
dan468's Avatar
D.U.I. Ignition and HEI for 67-72 trucks
What is everyone's opinion on DUI HEI distributors? There web site is pretty sweet; type in your engine info and presto, custom tuned spark and good prices too boot. Also, to change to a HEI ignition I was told to eliminate the factory resistor wire on the lead to the distributor which will make the supply 12-volt. I did that and everything works fine, however, I'd like to know if everything is up to full potential.
Thanks in advance for all responses!!!!
68 C-10
Build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=414699
dan468 is offline   Reply With Quote
Old 09-24-2007, 04:54 PM   #2
kwmech
Re: D.U.I. Ignition and HEI for 67-72 trucks
They have an awesome product. I have used them a couple of times in jeeps and such. But for a chevrolet, why not just use a factory distibutor? unless you are looking for something that is tricked out
Old 09-24-2007, 05:35 PM   #3
dan468
dan468's Avatar
I have a lot of $ in the engine and I didn't think I should stop at the distributer. The fact that they do the advance for you is pretty enticing.
68 C-10
Build thread
Old 09-24-2007, 09:45 PM   #4
diggertodd
diggertodd
diggertodd's Avatar
I'm running the DUI and the 18v voltage adapter, work flawlessly, with no other modificationss, moved the jets up 4 sizes, and that is noticable horsepower.
Did a magazine test on a 880 hp small block on a dyno at Ohio Crankshaft - HEI did everything for that engine that a MSD offered in side by side testing = good bunch of folks at Davis Unified Ignitions
diggertodd is offline   Reply With Quote
Old 09-26-2007, 07:57 PM   #5
dan468
dan468's Avatar
Is what I did when I removed the "resistor wire" what needs to be done? Or do I need anything else?
68 C-10
Build thread
Old 09-29-2007, 01:10 PM   #6
dan468
dan468's Avatar
Anyone? anyone?
68 C-10
Build thread
Old 09-29-2007, 01:14 PM   #7
short69
short69's Avatar
yep, all an HEI needs is a 12V supply thats hot on RUN and START. It also helps to have 10 guage wire.
69 shorty w/ 67 front clip
short69 is offline   Reply With Quote
Old 09-29-2007, 01:16 PM   #8
dan468
dan468's Avatar
sweet...Thanks!!
68 C-10
Build thread
