09-24-2007, 10:06 PM | #1 |
PITbut
Rust pics, YAY!
Here are some pics of my rust, and a pic of what parts i would need to order.
Here is the diagram. Here is a pic of the rocker rust. Those two circled spots are all the way through. The other two pictures are what it looks like from the bottom. What numbers on that diagram do i have to order for those parts??? Those wholes are DIRECTLY below the circled pictures. |
09-25-2007, 08:19 AM | #2 |
Spear and magic helmet!
Re: Rust pics, YAY!
Don't be ashamed of your rust. It's a badge of honor.
-- Will |
09-25-2007, 08:51 AM | #3 |
Re: Rust pics, YAY!
Here's what I would use, this and an outer rocker. You wouldn't have to use the whole thing if you don't need to.
Gary http://www.tri-proautomotive.com/ser...IES-ONE/Detail
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
09-25-2007, 10:27 AM | #4 | |
PITbut
Re: Rust pics, YAY!
09-25-2007, 10:53 AM | #5 |
Re: Rust pics, YAY!
Looks like that will take care of the areas of the floor and inner rocker that need to be replaced, but you'll also need to get an outer rocker. How are the cab supports ??? ( #'s 12,13,14 & 15 )
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 Last edited by CUSTOM/10; 09-25-2007 at 10:55 AM. |
09-25-2007, 10:56 AM | #6 | |
PITbut
Re: Rust pics, YAY!
So i need the inner floor and the outer rocker?? So in that top diagram, would i need #4,11,8 and 9??? |
09-25-2007, 11:02 AM | #7 |
Re: Rust pics, YAY!
You don't need 8 or 11. you need 4 lh & rh and 9 lh & rh. Item 4 will include 8 & 11 stamped in.
Or you can skip item 4 and use items 2 & 3 both lh & rh. This is what we used to do before item 4 was available (you'll do a little more cutting and welding, but you will spend about $100.00 less) This is the way I have always done it. Wait a minute! I just checked the link custom/10 posted. THAT'S what I would get, same part as LMC at a much better price. Good luck, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743 Last edited by raggedjim; 09-25-2007 at 11:11 AM. |
09-25-2007, 11:09 AM | #8 | |
PITbut
Re: Rust pics, YAY!
09-25-2007, 11:37 AM | #9 |
Re: Rust pics, YAY!
Sorry, I thought you had problems on both sides. Looks like you have an easy fix.
I think I might consider buying the outer rocker only and cutting out the bad sections of the inner. You could take the cut out section to a sheet metal shop (hvac guys usually can do it too) and have them bend up some pieces to weld in. Might save some $ Good luck, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743 |
09-25-2007, 11:43 AM | #10 | |
PITbut
Re: Rust pics, YAY!
09-25-2007, 12:42 PM | #11 |
Re: Rust pics, YAY!
I didn't even notice part #4 in the LMC picture, that's the same as the piece in the link that I sent. But the one from Tri-Pro is $40 less !!!
Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 Last edited by CUSTOM/10; 09-25-2007 at 12:45 PM. |
09-25-2007, 12:52 PM | #12 |
PITbut
Re: Rust pics, YAY!
09-25-2007, 01:01 PM | #13 | |
PITbut
Re: Rust pics, YAY!
I need to call up GMC paul and place the big order. |
09-25-2007, 03:01 PM | #14 |
Re: Rust pics, YAY!
Call up GMC Pauls and get them there. They will get you the correct items and they will talk to you and make sure you get the correct pieces. Plus they will be cheaper.
09-25-2007, 03:09 PM | #15 |
Re: Rust pics, YAY!
You should be golden, you can use the whole thing or just cut out the bad area and trim the new piece to fit. You'll know better how much of the piece you'll need once you get the outer rocker off. Get yourself a spotweld drill that will make removing the outer rocker easier.
Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 Last edited by CUSTOM/10; 09-25-2007 at 03:09 PM. |
09-28-2007, 08:48 AM | #16 |
Damn Yankee
Re: Rust pics, YAY!
LOL...we talk to people....they just need to call; but a lot of people prefer to just order online
09-28-2007, 10:18 AM | #17 | |
PITbut
Re: Rust pics, YAY!
I did place an order from you guys on tuesday 9/25 and received an email confirmation, but no email that my stuff has shipped. Any ideas?? Del Emerson runnin46@hotmail.com |
09-28-2007, 10:22 AM | #18 | |
PITbut
Re: Rust pics, YAY!
I still am getting the bed kit through paul. ahaha And a few other things... |
09-28-2007, 10:35 AM | #19 |
Damn Yankee
Re: Rust pics, YAY!
09-28-2007, 10:35 AM | #20 | |
Damn Yankee
Re: Rust pics, YAY!
09-28-2007, 03:20 PM | #21 |
its all about the +6 inches
Re: Rust pics, YAY!
I'm not trying to cut anyone out of any buinesess here... but you have a vendor just a few miles from you in Olimpia... Wes at Classic heart beat. He is a board supporter, and has a very good rep.
Two of the other vendors mentioned here are also outstanding vendors, also supporters of the site... but LMC totally sucks, I wouldn't spend a dime there unless they were the ONLY way to get rolling. |
09-28-2007, 03:34 PM | #22 | |
PITbut
Re: Rust pics, YAY!
