Old 09-25-2007, 12:10 AM   #1
xshadow
head Id
I have my valve covers off and want to Id my heads. where are the casting numbers and is there a site where I can ID the heads with the numbers
thanks
xshadow is offline   Reply With Quote
Old 09-25-2007, 12:20 AM   #2
67_C-30
I have a radical idea!
67_C-30's Avatar
Re: head Id
The are going to be between the rocker studs. You can't really miss them. Should be a 6 or 7 digit number like 3927186 or 333882. There will also be a letter/number code that is the casting date of the head. The first digit will be a letter representing the month, the second will be a 2-digit number representing the day, and the third will be the single digit number represent the year. For example, a head with the casting number 3973487 and a date code of E 24 2 will be casted on May 24, 1972.
You can ID the numbers here: http://www.mortec.com/castnum.htm
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 09-25-2007, 12:29 AM   #3
xshadow
Re: head Id
I didn't know if i should save these heads. I don't think there anything special
458642
Old 09-25-2007, 12:32 AM   #4
67_C-30
67_C-30's Avatar
Re: head Id
458642.....75-84...350..........350
468642.....76-up...350/400
If they aren't cracked I'd keep them. They aren't anything special, but def not junk. They would have hardened valve seats compatible with unleaded fuel unlike older heads.
My trucks
Old 09-25-2007, 10:54 AM   #5
Scott68-93-97
Scott68-93-97's Avatar
Re: head Id
The difference in the 468642 between the 400 and 350 is the 400 has steam holes drilled in the heads its a small 1/8 hole 2 in between each cylinder.
1968 Short Fleet 350/700r4
http://67-72chevytrucks.com/vboard/s...d.php?t=249435
1997 Bagged XtdCab Vortec350/4L60e
http://67-72chevytrucks.com/vboard/s...44#post2286144
1993 XtdCab Longbed 4x4 6.5Turbo/NV4500 "Daily Driver"
1985 Toyota XtdCab 4x4 22re/W-56/Dual T-cases, Doug Thorley Header, Homebrew front and rear spring packs, Tons of Mods to suspension and drivetrain, 35" boggers, coming soon ARB's and 5.29's, Possible 4.3/700r4 swap
Scott68-93-97 is offline   Reply With Quote
