How to keep my doors from closing
another question....forgive me if it's brainless but i'm new at all this.
my doors (driver/passenger) don't stay open. always close on me, especially when i'm parked on incline. seems like a simple fix...what specifically do i need to get to remedy this? thanks
"Some days you're the bug....Some days you're the windshield" 71 Blazer K5 |
The LuvShack Garage
Re: How to keep my doors from closing
The good - Sounds like the hinges are wore out.
The bad - Alot of the repop hinges are junk The solution - Get a rebuild kit from a Vendor
I've got grease on my mind.
Sounds like you need a new check link.
The LuvShack Garage
![]() ![]() Hard Luck, are you talking about the part in the middle of the hinge? I forgot about that part Epsorenson, it has plastic guides, I think ![]() *EDIT - just went out and looked on GQ, they look kinda plasticish ![]()
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T Last edited by LUV2XCLR8; 09-26-2007 at 06:06 PM. |
great....thanks guys
The LuvShack Garage
Hope we helped, if not we will be here when you come back and ask again
![]() Join Date: May 2006
Good answer guys, that rebuild kit should fix it...
![]() Join Date: Feb 2005
You will also probably need the friction pads that rub on the check link since they are usually not included in the rebuild kits. These pieces can get worn down so thin that they barely touch the check link. These are available throught the usual chevy truck parts houses(they are a little pricey).
'69 3/4 ton 427 CST Pickup '71 CST Blazer '72 GMC 3/4 4x4 |
sorry to be a pest.
i'm having trouble figuring out the vendor thing. can you guys tell me which vendor is near me in so cal that i can order the re-build kit from?
www.brotherstrucks.com is in so cal I belive..
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks ![]() |
#11 | |
can only find the entire hinge for sale. can't seem to locate rebuild kit with check link/friction pads. can anyone help? thanks again
How about Classic Industries, I used to buy alot of parts from them. They are in Huntington Beach, Ca. Where ever that is
#13 | |
they referred me to "hemmings" which seems to be a parts finding source. anyone else?
Might have to bite the bullet and buy Hinges, altho, that plastic pc. shouldn't be to hard to make. I just looked at mine, seems simple enuff
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 10-12-2007 at 06:13 PM. |
#15 |
SKINNY TIRES RULE!
Call Wes at http://classicheartbeat.com/. He's knows his stuff and can find the parts you need.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
#16 | |
seems like the check link/friction pads are almost impossible to get by themeselves ![]()
#17 |
just dug out an old set of hinges, seems like those friction blocks would be easy to make. All you have to do is knock out one roll pin and the whole gizmo falls apart. So you have to take the hinges off to get at the parts, why not buy a couple of used hinges off the classified, rebuild them and slap them on. Then you could sell your old hinges to the next guy with the same problem... JAT J.
