Texas Big Wig
Notch questions ???
I've been looking & the biggest bolt in notch I've seen is 2 1/4" deep
My question is: can I make a weld in notch with 3 maybe 4" pipe, if I box & plate the sides of the frame in that area ??? |
Re: Notch questions ???
4" pipe is only going to give you a 2" notch ... think about it.
ha. smart. maybe 6" pipe. that will give you 3". i almost missed that too....
You can use the smaller diameter pipe if you add 'legs' to extend the end of the 'C'. Cut the 4" dia pipe in half & then add straight sections of the same thickness of metal in whatever length you need @ the end of the 'C'. Basically the 'C' becomes a 'U' section.
But the 6" will offer more wiggle room.
#5 | |
Texas Big Wig
![]() I was tired, didn't even think about that But basically what can I get a way with here ??? |
#6 | |
Case in point: My 67 had the c-notch done w/the 4" dimension by a local shop. It clears the axle tube just fine..... but the pad that locates the housing to the trailing arm & the brake lines are a different story. I either have to re-do the c-notch or tweak whats there (which IMO looks like an after-thought). I decided to get another frame & do it over...... myself this time.
Hey Spay Bomb!! Sorry for offending you in the other post if you read it there is an apology never ment to make you mad but anyway, are you looking to just notch the frame or step it and either cut the floor or raise it, if you dont care about tubbing the hole truck or raising the floor check out the notches in my 97 build I can lay out on 22's with those
1968 Short Fleet 350/700r4 http://67-72chevytrucks.com/vboard/s...d.php?t=249435 1997 Bagged XtdCab Vortec350/4L60e http://67-72chevytrucks.com/vboard/s...44#post2286144 1993 XtdCab Longbed 4x4 6.5Turbo/NV4500 "Daily Driver" 1985 Toyota XtdCab 4x4 22re/W-56/Dual T-cases, Doug Thorley Header, Homebrew front and rear spring packs, Tons of Mods to suspension and drivetrain, 35" boggers, coming soon ARB's and 5.29's, Possible 4.3/700r4 swap |
You know that we make a notch that's designed to match the contour of the 60-72 C10 frames. You can shorten the sides and top cap to be the exact heigth that you're looking for, and it will be super easy to install because of the shape.
Here's an image of the notch to give you an idea of the shape. ![]() Let me know if you have any other questions, or think this will help you with your project.
#9 | |
senior member
69 GMC bagged |
#10 | |
#11 | |
Texas Big Wig
Scott I'm cool, I think you got my PM
SCOTI... I think that 4" is prolly too close for comfort, so do you think 6" would be good ??? Clint... I just haven't decided if I want to cut up my floor or not, main reason being that my front can only go so low right now & I dunno if I want to make the capable of going lower than the front (It's just never low enough for me, so I may go ahead & make the rear do what I want, and the make the front lay later) |
6" works well on c-notches. If you want (need) more height for the top of the notch.... add the 'legs' @ the end of the 'C'.
If you want to do a notch and keep the original bed floor intact, then the notch will have to be extremely small. Reasone being is that the frame on the 60-72 trucks kicks up right over the axle and there's only 1 inch of clearance between the bed floor and frame rail in that area. The bed floor support rail actually sits on top of the frame there.
#15 | |
#17 |
gonna be pretty difficult to get the offset that occurs over the rear axle with a curved unit like that ...
#18 |
It would be just as easy as the others start out with the side plates break them and theyed have to make a wider top and bottom peices and just cut out what you dont need after the bends, they'de be produced just like the others just round, the notches start out as 4 peices. Who knows maybe I'll get around to mach'n one up and see how it turns out
#19 |
Texas Big Wig
Wonder if they could do it like the other one & build it in pieces so it's not really bent pipe, but welded plate ???
#20 |
They are seperate peices I just cut in into the edges at a 45 and welded em up and barely ground any weld off to give them the smooth look
