C10 Club Tennessee
Fuel Pump Question
I have a SBC out of a 91 burb, which obviously had a electric fuel pump in the tank. Well I'm putting it in my blazer and am going to use the fuel pump on the block. It's has a plate over it which I took off, but the new pump I got doesn't match up the bolt holes. What am I missing??? I know this is a stupid question but I still need to know
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
![]() Join Date: Feb 2004
Re: Fuel Pump Question
Any Pics?, there is a rod the had to be pushed up before the botl holes will line up.
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
vtheres a little metal plat that goes on the block to mount the pump available in plain steel chrome or billet from places like summit speedway motors pepboys etc
#4 | |
![]() Example ![]() Mr Gasket p/n 1514 $6.95
2003 GMC Sierra 1500 WT 1995 Nissan Hardbody 2016 Hyundai Veloster Turbo DC2 (SW/AW) Clyde W. Harvey USN "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill Last edited by brak; 09-27-2007 at 06:27 AM. |
C10 Club Tennessee
Thanks, that looks like it will work.
I Thought That After Gm Went To Throttle Bodies They Didnt Machine A Hole For The Fuel Pump Push Rod To Go Through?
Im Not Even Shure There Is A Cam Lobe To Drive It?
72 2wd lwb cheyenne super youngest son.green/white 72 2wd lwb cheyenne super oldest son.green/white 71 4wd 3/4 cheyenne super frame off manderin copper / white 4 inch lift. FINALLY DONE / SOLD 72 4WD SWB CHEYENNE BLUE/WHITE 388 AUTO REMEMBER THE COPS NEVER THINK ITS AS FUNNY AS YOU DO. NORWOOD SURVIVOR COPPERTONE BUILD THREAD/ http://www.67-72chevytrucks.com/vboa...d.php?t=259856 |
#7 | |
I pulled a fresh motor from a 89 blazer (TBI, Centerbolt heads) to swap into my camaro, and all i had to do was remove the block off plate, and install the mechanical fuel pump. It worked great. ![]()
2003 GMC Sierra 1500 WT 1995 Nissan Hardbody 2016 Hyundai Veloster Turbo DC2 (SW/AW) Clyde W. Harvey USN "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill |
laying low
![]() Join Date: Mar 2001
I imagine GM had quite a few blocks with the holes already machined in them to use up once they went with tank mounted pumps. I've heard engines as late as 93 could still have had the holes in them. No problem if one doesn't as you can always plumb in an inline electric one if need be.
C10 Club Tennessee
There is a rod in there, it was all gummed up and it was a pain to get out. I hope there is or I'm screwed.
if theres a rod in there it could be held in place by the bolt at the front of the block// if it is get shorter bolt after fuel pump install
C10 Club Tennessee
No, I could tap it back and forth from the cam to the plate.
if that rod keeps falling down while yr trying to put the fuel pump on, take some sticky grease and coat the rod good and push it all the way up, it wil stay there long enuff to get yr pump on and start yr bolts.good luck
1969 rs 1966fastback 1969swbc/10 2006gt 1972swb4x4 |
